The Kuka I run is used exclusively for milling, which generates some ridiculously large files. It's a KRC2 controller running KSS5.4.14 - can I just select a header file that's on the USB stick, and run it from there? I'm having to split programs up a lot at the moment - the milling routine that it's running right now is split into six sets of files, because the available onboard space is so small - it won't let me upload more than 15 linked files - this current job breaks down into 48 files total.
I'm reluctant to just try it out, because I simply don't know if it's going to cause any readahead problems (or whatever the Kuka equivalent is) due to the slow USB bus speed - can anyone here verify if it would work?
