MODE AUTO FANUC
  • Hello guys,
    i want to run a program in auto mode, and i have no buttons on the controller so i want to use 4 PB (START, RESET, HOLD or STOP and another start from zero)
    I just want to have the possibility to choose between starting the program from zero and to continue where it did stop.
    How can i do that pls!
  • Use the UI signals. You can read about UOP in the manual.
    There is a UI signal for Reset, Hold, Abort, Start, and Prod Start.
    You would use Start to continue and Prod Start to start from 0.
    To do so you must go to the system config and set "start to continue only".
    To start over from 0, they must press Abort then Prod Start.
