Types of backups
  • C_hiney
  • February 17, 2022 at 11:31 PM
  • C_hiney
    32
    Can someone explain the difference between fanuc's auto back up software (pc file services 2008) ,FTP back ups, and a local All of the above? Also FTP backups useable to restore? If so does the controller ignore the ascii formatted files? Working on getting away from file services 2008 and the new service is FTP
  • HawkME
    570
    3,270
    • February 18, 2022 at 2:05 AM
    All of the above doesn't include ASCII. An FTP backup should work with the restore function, but usually I just send all files with FTP while the robot is in a controlled start if I need to do that and don't bother with the Fanuc restore.
  • cobenson
    10
    314
    • February 18, 2022 at 12:06 PM
    Quote from HawkME
    After you perform an all of the above backup, depending on the robot controller, you can also do an ascii backup from the same screen.
  • retobor
    18
    207
    • February 18, 2022 at 9:21 PM
    Quote from cobenson
    Alternatively, set your backup folder location, then set MD, F4 SAVE AS will backup AOA and LS in one shot.
Similar Threads
  • Installing KUKA.Ethernet IP 1.1 Scanner/Adapter
    • mcasa0802
    • May 14, 2020 at 1:29 AM
    • KUKA Robot Forum
  • ABB mystery robot. No tag on control panel and startup issues
    • jackofalltrade
    • March 25, 2017 at 1:54 PM
    • ABB Robot Forum
  • Troubleshooting KRC4 Compact _ KR10 R1100 Sixx Agilus
    • robbie_newbie
    • February 20, 2020 at 9:42 AM
    • KUKA Robot Forum
  • kr210 vibrate when jogging the axes
    • ROBOT_LIU
    • December 24, 2018 at 12:40 PM
    • KUKA Robot Forum
  • FTP
  • all the above
  • PC file services
