  4. ABB Robot Forum
S4C missing Input signal
  • Sean_MMSNI
  • February 11, 2022 at 9:04 AM
  • Sean_MMSNI
    123
    I have an S4C controller here for an IRB6400 robot, I have some of the I/O connected to another robot and other equipment, recently I have added another 4 Inputs from a PLC.
    The problem I am having is the robot keeps missing the signal even though it has a constant 24v going to it. It reads the signal most of the time while the robot is running through the program however it seems to not be able to read the signal during some parts of the program.
    I have tested this by watching the indicator leds on the I/O board and it lights up and then it will start to flicker and turn off. I have tested this with a multimeter held to the specific Input I am testing and it has a constant 24v the whole time even when the led turns off.
    The power for the bank of inputs I am having problems with is coming from the robot itself.
    Does anyone have any idea what is going on, I have the first bank of inputs wired up and they work perfectly so I am unsure what is going wrong.
    I have attached photos of the I/O
  • hermann
    407
    2,611
    • February 11, 2022 at 9:35 AM
    • Best Answer
    - You should measure against Pin 9 of the same connector where the signal is (X4). May be a weak 0V connection to this bank.
    - try a direct connection to 24v to the desired input
    - otherwise hardware defect of the DSQC
  • Sean_MMSNI
    123
    • February 11, 2022 at 10:02 AM
    Quote from hermann
    I have measured against pin 9 of the same connector, it was just easier to take a photo as shown.
    I should mention, when the robot is stationary the I/O remains on constantly and never seems to cut out.
    I will try connect constant 24v to the board the next time it is running and check it.
  • Lemster68
    301
    2,469
    Blog Articles
    7
    • February 11, 2022 at 2:03 PM
    The wires on 7 look a bit sloppy. Try moving the one in question to 8, it is open from your pic. Check the cabling.
  • Skooter
    169
    2,025
    • February 12, 2022 at 3:02 AM
    hermann is right. Electrically, that input is the current path between X4-4 & X4-9 and that is where you must measure.
  • Sean_MMSNI
    123
    • February 14, 2022 at 3:19 PM
    I found the problem, it was a partial internal breakage in the wire for pin 9. Replaced it and all is working fine now.
    Thanks for all of your suggestions.
Similar Threads
  • Error SYST-034 HOLD signal from SOP/UOP
    • kicaj073
    • May 18, 2018 at 8:24 AM
    • Fanuc Robot Forum
  • KRC4 - Custom Weld Timer
    • notverycreeative
    • December 5, 2021 at 1:33 AM
    • KUKA Robot Forum
  • SSO[5] C_NTED Help Needed
    • RockyLeafs
    • October 22, 2018 at 7:29 PM
    • Fanuc Robot Forum
  • Input AUTO confirmation signal
    • sklemp
    • May 24, 2019 at 5:35 PM
    • Fanuc Robot Forum
  • Pick Master 3 - Strobe signal missing
    • ClaudiuA
    • January 8, 2022 at 1:28 PM
    • ABB Robot Forum
  • NX100 PLAY MODE ENABLE signal input / button missing
    • norkator
    • January 29, 2021 at 10:26 PM
    • Yaskawa Motoman Robot Forum
  • NX100 Ethernet functionality experience
    • norkator
    • January 17, 2021 at 5:52 PM
  • K6SB PROBLEM,,, ALARM 2020 MISSING ARC GENERATION CONFIRM
    • CtulhuAdept
    • November 14, 2018 at 5:59 AM
  • System Input Not Functioning
    • SelectRobot
    • March 21, 2018 at 2:26 PM
    • ABB Robot Forum
