KAREL to Write Robot I/O Comment
  • iProg83
  • January 31, 2022 at 9:13 PM
  • iProg83
    14
    So I am starting out with KAREL-
    I have the programming and reference bibles (manuals)
    I am looking at a couple of the built-ins for writing the comment for a robot I/O. I change EOATs often and their nomenclature is never the same to actuate the grippers, vacuum generators, etc.
    I have seen these two built-ins;
    RSET_PORTCMT
    SET_PORT_CMT
    I am struggling to follow which one is more suitable for what I am attempting to accomplish.
    I want to be able to call the procedure/routine (I have seen this used both terms in the manual)
    AR[1]- type of i/o (DI,RI,DO,RO,AI, etc)
    AR[2]- number of the i/o
    AR[3]- comment of i/o as a string
    I feel like the SET_PORT_CMT is the appropriate one to use- am I on the right path?
  • Go to Best Answer
  • EnergyAddict
    45
    133
    • January 31, 2022 at 10:16 PM
    I'm by no means a Karel Expert, but I've dabbled.
    Yes you are on the right path.
    SET_PORT_CMT can be used to set I/O comments
    You may also want to look at SET_REG_CMT, SET_PREG_CMT, SET_SREG_CMT for registers, Position Registers, and String Registers.
    Reading Arguments can be accomplished with GET_TPE_PRM.
  • iProg83
    14
    • February 1, 2022 at 8:42 PM
    Oof-
    Ok I am guessing that I will need to write much more code to accomplish this.
    I will continue reading the manual as much as I can.
    My code is a jumbled up mess at the moment. I am wishing I could find examples of passing multiple arguments in the manual. I haven't read the whole thing yet- that will take a bit.
  • EnergyAddict
    45
    133
    • February 2, 2022 at 2:29 PM
    • Best Answer
    Honestly, It probably sounds like more than it really is. Curiosity got to me, so I tried it myself, and it wasn't that much code.
    If you're interested, below is how I accomplished it.
    I'm sure there is probably more error checking that can be done with the STATUS variables, but I don't know much about them, I got them out of another source code I had a copy of.
    I followed the AR[] structure from your original post; AR[1] = IO_type, AR[2] = IO_Num, AR[3] = IO_cmt.
    The IO_type variable gets passed as an integer who's value comes from KLIOTYPS.KL (See the list below) and then I have a SELECT CASE setup for the Registers; pass a 1000, 1001, or 1002 for Num-Reg, Pos-Reg, or String-Reg respectively.
    (Setting this program up in ARGDISPEG01.DT would also be a good idea)
    io_din = 1 -- Digital input
    io_dout = 2 -- Digital output
    io_anin = 3 -- Analog input
    io_anout = 4 -- Analog output
    io_rdi = 8 -- Robot digital input
    io_rdo = 9 -- Robot digital output
    io_gpin = 18 -- Grouped inputs
    io_gpout = 19 -- Grouped outputs
    io_flag = 35 -- Flag (F[ ])
    io_marker = 36 -- Marker (M[ ])
    PROGRAM ARG_CMTS
    %NOPAUSE = TPENABLE
    %COMMENT = 'ROBOT COMMENTS'
    %ENVIRONMENT REGOPE
    %ENVIRONMENT IOSETUP
    %ENVIRONMENT STRNG
    %INCLUDE kliotyps
    VAR
        int_value, STATUS, IO_Num, IO_type   :INTEGER
        real_value  :REAL
        IO_cmt, str_value  : STRING[32]
    BEGIN
        GET_TPE_PRM(1, 1, IO_type, real_value, str_value, STATUS)
        GET_TPE_PRM(2, 1, IO_Num, real_value, str_value, STATUS)
        GET_TPE_PRM(3, 3, int_value, real_value, IO_cmt, STATUS)
        IF IO_type >= 1000 THEN
            SELECT IO_type OF
            CASE(1000):
               SET_REG_CMT (IO_Num, IO_cmt, STATUS)
           CASE(1001):
               SET_PREG_CMT (IO_Num, IO_cmt, STATUS)
           CASE(1002):
               SET_SREG_CMT (IO_Num, IO_cmt, STATUS)
            ENDSELECT
        ELSE
            SET_PORT_CMT(IO_type, IO_Num, io_cmt, STATUS)
        ENDIF
     END ARG_CMTS
    Edited once, last by EnergyAddict (February 2, 2022 at 2:35 PM).
  • iProg83
    14
    • February 2, 2022 at 3:30 PM
    Energy addict-
    Thank you a very much. This does help out.
    I was reading in my manual yesterday about KLIOTYPS.KL. I was unable to find any of this when I searched in my manual. I was really hoping there was more about it in the appendix.
    I definitely have some studying to do here.
  • EnergyAddict
    45
    133
    • February 2, 2022 at 3:43 PM
    Quote from iProg83
    I found the KLIOTYPS list on this thread KLIOTYPS.KL
    Glad I could help.
Similar Threads
  • Software Request to Fanuc - the robot forum bugs and wish list
    • Werner Hampel
    • August 17, 2019 at 11:12 AM
    • Fanuc Robot Forum
  • PC and FANUC robot TCP/IP Communication
    • mahboobelahi93
    • September 24, 2021 at 4:02 PM
    • Fanuc Robot Forum
  • INTP-105 Run request failed, trying to start program with RUN_TASK built-in
    • FLrobotics
    • November 12, 2020 at 4:40 PM
    • Fanuc Robot Forum
  • Call TP program from KAREL
    • Limburger
    • May 20, 2021 at 4:30 PM
    • Fanuc Robot Forum
  • Fanuc Karel Server, MSG_CONNECT exits with status 67206 without blocking
    • KlausSu
    • April 18, 2019 at 11:14 AM
    • Fanuc Robot Forum
  • SAVE Macro with KAREL program
    • Famous_Fella
    • April 1, 2020 at 9:47 AM
    • Fanuc Robot Forum
  • KAREL - Problems for generate an output answer (R[ ], DOUT ...)
    • RobBrain34
    • November 7, 2019 at 7:59 PM
    • Fanuc Robot Forum
  • Communication going between cognex and fanuc robot
    • pramtekkar
    • June 5, 2019 at 4:42 PM
    • Fanuc Robot Forum
