Hi there!
First of all, I would like to say a huge thank you to all the active forum members - you share invaluable information!
Special thanks to SkyeFire and PanicMode - you guys are my heroes.
So, the problem is this.
I am making a small adaptive program to weld intermittent seams with given characteristics (e.g. 30/100 = 30 mm welding, 70 mm no welding, and so on throughout the seam).
The program automatically builds a discontinuous weld between any two points with the specified characteristics, with approaches and waste, with the specified tool orientation.
The basic idea is to find the direction cosines of the trajectory vector (and the rotation angles, respectively) move the base to the origin of this vector, and align the X-axis of the base with this vector.
But, it doesn't work on the robot the way I expect it to.
If I build a path from the first point to the second point from left to right, the robot moves from right to left after the program runs.
Any advice would be appreciated.
KR8 R2010 KSS 8.6.8
BASE_DATA[32] = $NULLFRAME
$BASE = BASE_DATA[32]
; Here we need to change the value of the variable "w" to the actual length of the seam.
w = 50
; Here we need to change the value of the variable "t" to the total length of the step.
t = 100
; Here you can disable welding of the last incomplete segment.
; 1 - ON , 0 - OFF
weld_last_segment = 1
NACHALO_ROTATE = $NULLFRAME
KONEC_ROTATE = $NULLFRAME
ROTATE_POINT = $NULLFRAME
PTP XHOME
counter = 1
T1_x = XNACHALO.X
T1_y = XNACHALO.Y
T1_z = XNACHALO.Z
T2_x = XKONEC.X
T2_y = XKONEC.Y
T2_z = XKONEC.Z
T1T2_x = T2_x - T1_x
T1T2_y = T2_y - T1_y
T1T2_z = T2_z - T1_z
l = SQRT(SQUARE(T1T2_x) + SQUARE(T1T2_y)+ SQUARE(T1T2_z))
n = l / t
n_int = n
IF (n - n_int) < 0 THEN
n_int = n_int - 1
ENDIF
final_w = t*(n - n_int)
IF final_w >= w THEN
final_w = w
ENDIF
cos_a = T1T2_x /SQRT(SQUARE(T1T2_x) + SQUARE(T1T2_y))
angle_a = ACOS(cos_a)
cos_z = T1T2_z /l
angle_z = ACOS(cos_z) - 90
BASE32_SHIFT = $NULLFRAME
BASE32_SHIFT.X = XNACHALO.X
BASE32_SHIFT.Y = XNACHALO.Y
BASE32_SHIFT.Z = XNACHALO.Z
BASE32_SHIFT.A = angle_a
BASE32_SHIFT.B = angle_z
BASE32_SHIFT.C = 0.0
BASE_DATA[32] = BASE32_SHIFT ; move the Base32 to the beginning of the weld vector
NACHALO_ROTATE = ReturnPosRelToBase(XNACHALO, $NULLFRAME, BASE_DATA[32]) ; recalculate the tool orientation in
KONEC_ROTATE = ReturnPosRelToBase(XKONEC, $NULLFRAME, BASE_DATA[32]) ; the angles of the final offset Base32
XNACHALO.X = 0.0
XNACHALO.Y = 0.0
XNACHALO.Z = 0.0
XNACHALO.A = NACHALO_ROTATE.A
XNACHALO.B = NACHALO_ROTATE.B
XNACHALO.C = NACHALO_ROTATE.C
XKONEC.Y = 0.0
XKONEC.Z = 0.0
XKONEC.A = KONEC_ROTATE.A
XKONEC.B = KONEC_ROTATE.B
XKONEC.C = KONEC_ROTATE.C
WHILE counter < n
XKONEC.X = ((counter - 1)*t + w)
FAPPROACH = FNACHALO
XAPPROACH = XNACHALO:SHIFT
LIN XAPPROACH
;FOLD ARCON WDAT1 LIN NACHALO Vel=1 m/s CPDAT2 Tool[1] Base[32] ;%{PE}
;FOLD Parameters ;%{h}
;Params IlfProvider=kukaroboter.arctech.arconlin; Kuka.IsGlobalPoint=False; Kuka.PointName=NACHALO; Kuka.BlendingEnabled=False; Kuka.MoveDataName=CPDAT1; Kuka.VelocityPath=1; Kuka.CurrentCDSetIndex=0; Kuka.MovementParameterFieldEnabled=True; ArcTech.WdatVarName=WDAT1; ArcTech.Basic=3.3.4.387
;ENDFOLD
$BWDSTART = FALSE
LDAT_ACT = LCPDAT1
FDAT_ACT = FNACHALO
BAS(#CP_PARAMS, 1.0)
SET_CD_PARAMS (0)
TRIGGER WHEN DISTANCE = 1 DELAY = ArcGetDelay(#PreDefinition, WDAT1) DO ArcMainNG(#PreDefinition, WDAT1, WP5) PRIO = -1
TRIGGER WHEN PATH = ArcGetPath(#OnTheFlyArcOn, WDAT1) DELAY = ArcGetDelay(#GasPreflow, WDAT1) DO ArcMainNG(#GasPreflow, WDAT1, WP5) PRIO = -1
TRIGGER WHEN PATH = ArcGetPath(#OnTheFlyArcOn, WDAT1) DELAY = 0 DO ArcMainNG(#ArcOnMoveStd, WDAT1, WP5) PRIO = -1
ArcMainNG(#ArcOnBeforeMoveStd, WDAT1, WP5)
LIN XNACHALO
ArcMainNG(#ArcOnAfterMoveStd, WDAT1, WP5)
;ENDFOLD
;FOLD ARCOFF WDAT1 LIN KONEC Vel=1 m/s CPDAT2 Tool[1] Base[32] ;%{PE}
;Params IlfProvider=kukaroboter.arctech.arcofflin; Kuka.IsGlobalPoint=False; Kuka.PointName=KONEC; Kuka.BlendingEnabled=False; Kuka.MoveDataName=CPDAT2; Kuka.VelocityPath=0.033; Kuka.CurrentCDSetIndex=0; Kuka.MovementParameterFieldEnabled=True; ArcTech.WdatVarName=WDAT1
;ENDFOLD
$BWDSTART = FALSE
LDAT_ACT = LCPDAT2
FDAT_ACT = FKONEC
BAS(#CP_PARAMS, gArcBasVelDefinition)
SET_CD_PARAMS (0)
TRIGGER WHEN PATH = ArcGetPath(#ArcOffBefore, WDAT1) DELAY = 0 DO ArcMainNG(#ArcOffBeforeOffStd, WDAT1) PRIO = -1
TRIGGER WHEN PATH = ArcGetPath(#OnTheFlyArcOff, WDAT1) DELAY = 0 DO ArcMainNG(#ArcOffMoveStd, WDAT1) PRIO = -1
ArcMainNG(#ArcOffBeforeMoveStd, WDAT1)
LIN XKONEC
ArcMainNG(#ArcOffAfterMoveStd, WDAT1)
;ENDFOLD
XAPPROACH = XKONEC:SHIFT
LIN XAPPROACH
XNACHALO.X = counter * t
counter = counter + 1
ENDWHILE
DEFFCT FRAME ReturnPosRelToBase(p:IN, baseSrc:IN, baseDst:IN)
FRAME res, p, baseSrc, baseDst
;Equation:
;baseSrc : p = baseDst : res
res = INV_POS(baseDst) : baseSrc : p
return res
ENDFCT
