Can someone help me out here? I'm having tip increase faults after every tip change.
SVGN-032 Tip increase error occurring after tip change
- AlanT96
- Thread is Unresolved
AlanT96
Changed the title of the thread from “SVGN-032” to “SVGN-032 Tip increase error occurring after tip change”. -
This is a common issue on new custom guns during their break-in period. There could be several problems here, the help diagnostics on the pendant is descriptive for this fault. If it is constantly happening every cycle, your caps look ok, and TW_SETG1 was run properly, it may be time for an autotune.
If autotune does not fix the issue, I know changing these system variables can resolve the issue: $SGSYSCFG.$MINIMUM_TRQ from 1 (default) to 100, and $SGGUNx.$SGTWD.$DIV_STROKE to 100 (x being your gun number). I have not been told what these variables do exactly.
Thanks, i have never ran Autotune before. Can I run it during production, when they go to lunch? or could it cause any issues where I need to wait till a weekend to do it?
If you have never run it before, it is probably best to wait for the weekend. It isn't difficult, but there is a procedure to follow. You must verify gun parameters and perform a gun zero master with fresh caps.
After rereading your original post, I am now confused. Is the tip increase fault after a cap change, or a tip dress? or both? I was assuming this was occuring after a tip dress because the wear update program is called after a dress, I believe.
it is happening after tip dress. But only the tip dress that happens immediately after changing caps
Has this always been a problem? Which direction is being used as gun open? Was TW_SETG1 mastered properly with new caps?
It's been a problem as long as I've been working here. (A few months) I guess people have just been hitting auto every time. It only cap changes about 2 or 3 time a shift. I believe it was mastered properly. It is group 2 X- to open X+ to close if that's what you're asking.
If this is the case, it sounds like the reference isn't being reset after new caps. What is AR[2] for the program you've shown above? It looks like the wear is reset with the program call on line 52 if this register does not equal 1.
how do I look at AR? Register 10 is showing 1 at the moment.
