Hi everybody. At my company,
they changed a welding gun. so now i want to "calibrate" zero the original of the welding gun. please help me
All that information is readily available in the Servo Weld Gun Instruction manual.
Upon a physical gun change, if it is identical, then just going through the connection procedure in the manual, should re-zero itself - new tips must be fitted or incorrect values will be set.
Thanks admin !!!!
hello admin! can you send the document Servo Weld Gun Instruction manual.
please help me. thank you so much!!!
Thank you so much!!!! Admin
