Timing pulley like Bevel Gears
RobotDee -
January 24, 2022 at 5:33 AM -
- Best Answer
belts can be twisted. case b seem to be what you are after. it requires two idle rollers (smooth, no teeth).
Oh nice! I did not know we can twist the belt like that.
Thank you
Actually some KUKA robots used the same setup in wrist.
notice that idlers (guiding pulleys) are barrel shaped. this is used to guide belt back to center of the idler.
External Content www.youtube.comContent embedded from external sources will not be displayed without your consent.Through the activation of external content, you agree that personal data may be transferred to third party platforms. We have provided more information on this in our privacy policy. -
A question for Case c: does it work also if we twist the belt to right instead of left, so all idle got teeth?
if you watch closer case "a" and the yourtube video in previous post, you will see that toothed side of the belt can be on idler too. btw "a" and "b" are actually the same setup. the front gear is simply rotated about axis of idlers.
in case "a" it is up ("12 o'clock"), in case "b" it is down at "9 o'clock". so in case "a" belt just wraps more about idlers. you can literally take that gear and while keeping belt tension move it all around (12,11,10,9...6 o'clock). that is full 180deg placement range.
You are right, i understand, thanks.
