  4. Kawasaki Robot Forum
TCP multiple tools
  • Alexandru
  • January 21, 2022 at 11:22 AM
  • Alexandru
    49
    407
    type in the terminal list /l tool1 and list /l tool2 and you should have tool1 and tool2 points.
  • Alexandru
    49
    407
    • January 21, 2022 at 2:47 PM
    That is your problem... TOOL1 and TOOL2 are used only using block programming.
    You need to create the tool1 and tool2 points and put the QTOOL to OFF.
  • kwakisaki
    694
    4,770
    • January 21, 2022 at 2:48 PM
    George32
    It would serve you well to read up on the following:
    SYSTEM SWITCH QTOOL
    BLOCK Programming tool Coordinate setup
    AS Programming tool Coordinate setup
    TOOL1 etc in the AS file relate to tool data set in Aux 0304.
    (This is the data you are seeing in your AS file).
    Your code is using AS Language tool commands, which cannot directly address Aux 0304 values as this tool data is used for BLOCK programming.
    When using TOOL xxxx AS Language command, this actually uses a location transformation variable you have previously defined or by direct transformation value entry.
    If tool1 and tool2 transformation values are not defined, then an undefined variable error will result.
    Exactly as your code is.....so what you are seeing is correct.
    So to resolve your issue if you are only using AS Language, you need to:
    1. QTOOL OFF
    2. Define tool1 and tool2 as transformation variables by:
    POINT tool1 = TRANS(-307,0,15.5)
    POINT tool2 = TRANS(-167.1,0,-67)
    Your robot will then move to a and b relative to the tool used after executing the AS tool command.
Similar Threads
  • Fanuc 2D vision 100+ Part Types
    • McNorgs
    • June 17, 2021 at 2:49 PM
    • Fanuc Robot Forum
  • iRVision
    • VHS
    • June 8, 2021 at 10:03 AM
    • Fanuc Robot Forum
  • 2DIRvision Camera
    • moelsayed
    • March 11, 2021 at 4:21 AM
    • Fanuc Robot Forum
  • Kuka Style Guide
    • MaxG
    • November 21, 2020 at 12:33 PM
    • KUKA Robot Forum
  • XRC - Tool Data modification
    • lostcontrol
    • October 8, 2020 at 11:24 AM
    • Yaskawa Motoman Robot Forum
  • User Tools becoming un-editable in Roboguide
    • Erik Olsen
    • June 5, 2020 at 10:30 PM
    • Fanuc Robot Forum
  • Get Tool
    • Noob1982
    • December 10, 2019 at 4:25 PM
  • IRC5 rw6 Safemove Pro
    • Plc_User
    • March 2, 2019 at 12:21 AM
    • ABB Robot Forum
  • Kuka Automatic Tooltip calibration for CNC operations
    • callumq
    • September 24, 2018 at 9:06 AM
    • KUKA Robot Forum
  • DCS Tool Frame
    • amar15t
    • May 12, 2018 at 8:34 PM
    • Fanuc Robot Forum
Users Viewing This Thread
  • 1 Guest
