Adding I/O in R30iA controller
  • RainbowShadow20
  • January 20, 2022 at 2:43 PM
  • RainbowShadow20
    5
    Hi, a bit new in robotic.
    At my internship, we have 2 R30iA controller but it seems like there's no I/O port on it. I took a look at another cabinet in the shop and it has an I/O interface connected to a row of yellow I/O port via an I/O link cable.
    In the manual, the CRMA58 and CRMA59 ports are the ones where the needed card should be connected to, am I wrong?
    My question is, what module/card do I need to have I/O ports on my R30iA controllers?
    Thank you for your precious help!
  • TitusLepic
    113
    7
    442
    • January 20, 2022 at 5:37 PM
    Do you have a copy of the FANUC Robotics I/O Unit–MODEL A Connection and Maintenance Manual? It has all the info you need.
    My manual came with an RJ3iB controller, but I expect it would be the same for the R30iA - here's what it says you need:
    A base unit (they come in 5 and 10 slot, horizontal and vertical - ABU05A, ABU10A, ABU05B, and ABU10B0
    An interface module (AIF01A, AIF01B, or AIF02C)
    An I/O link cable (K1X) going from JD1A on the controller to JD1B on the interface module
    Power cable - make your own. My manual calls for an SMS3PN-5 housing with RC16M-SCT3 pins, but both of these have been discontinued by the manufacturer - I was able to find compatible replacements when I did this project last year.
    I/O cards - See attached images.
    As I said, this is from an RJ3iB manual; but should at lease get you pointed in the right direction until somebody more knowledgeable comes by with a better answer.
Similar Threads
  • SRAM vs DRAM
    • alive15
    • August 5, 2020 at 6:22 PM
    • Fanuc Robot Forum
  • Fanuc Override adjust
    • jariuscs
    • August 5, 2019 at 11:52 PM
    • Fanuc Robot Forum
  • Adding a rotary table
    • mjktech
    • June 14, 2019 at 12:31 AM
    • Fanuc Robot Forum
  • Adding IRVision - Sony XC56
    • ESIELI
    • January 21, 2019 at 7:52 PM
    • Fanuc Robot Forum
  • Adding a RUN program into a MAIN.
    • Drak29
    • September 24, 2018 at 7:46 PM
    • Fanuc Robot Forum
  • R30iA
