Hello everyone. I need help with an issue, I hope you can help. On my IRC 5 Robot, for example, in the Weld_Left Routine file, I want to check the water flow before each source of the robot. As an example I have a signal called WaitDI waterflow_ok. Robot codes in the Routines file: 1-MoveJ
2-MoveL
3-WaitDI waterflow_ok
4-Spot
5-MoveL
6-WaitDI waterflow_ok
7-Spot
8-MoveL
9-WaitDI waterflow_ok
10-spot
this way, instead of adding WaitDI waterflow_ok command one by one before each spot command, by adding one command to this routine file
I want to ensure that the robot does not continue its movements when the WaitDI waterflow_ok signal is not received. How can I do that? Does anyone have knowledge? Thanks.
