Hi.
My IRB 460 Suddently stopped and got Msg as below
"Event Message 34312" Missing drive unit.
I found that Main Drive unit inside Red color light is On.
Is anybody can help.me how to solve it.
Hi.
Check for loose connections and bent pins. Do a backup and try a reboot. If the Light fails to go green, check your power supply voltages. If they check out, you probably have a bad drive unit which needs replacing. Look through your error logs for any other clues.
Did you have any power surges? Fires? Lightning? Roof leak? Any more clues?
In the future It would help if you let us know what controller you have and what software you are running.
