8.3>8.5 Point Conversion
  • freak
  • January 11, 2022 at 7:31 AM
  • freak
    17
    Good Morning
    Is there any way to change a 8.3 Point Ptp/Lin to 8.5 oder higher point?
    Greetings F
  • Fubini
    272
    1,873
    • January 11, 2022 at 9:53 AM
    Since its only text of course. Whats the difference between those two?
    Fubini
  • panic mode
    1,268
    13,040
    • January 11, 2022 at 2:27 PM
    go to robot with KSS 8.3, create new program module and add motion instruction of each type (PTP, LIN, ....). maybe call this program module KSS83.SRC and KSS83.DAT
    transfer copy of that module to robot with KSS8.5. this is executable as is.
    but to have each motion saved in new format, click on Change etc. for each of the motions. for example one of changes is collision detection. rename module to KSS85.
    bring both modules KSS83 and KSS85 to your computer and use some sort of compare program (KDIFF, WinMerge,BeyondCompare or whatever).
    once you know what the differences are, it is possible to use search and replace. but ... do not do it by hand. that is time consuming, error prone and would only work on one file.
    get FNR.EXE for example (http://findandreplace.io/) and create a script. then use that script to modify any module (or number of modules) in seconds, any time you need to make the change.
  • freak
    17
    • January 11, 2022 at 6:21 PM
    Hey panicmode
    I can't press change on the 8.3 inlineforms on the 8.5 controller.
    I think this is because of the version.
    Is there any other possibility?
  • freak
    17
    • January 11, 2022 at 6:22 PM
    Hi fubini
    The problem is i can't change any options on the "old" points.
  • panic mode
    1,268
    13,040
    • January 11, 2022 at 7:36 PM
    that is odd... i don't remember having such problem and i have done several migrations.
    recently i have done few in reverse - things developed on 8.5 had to work on older systems with 8..3.
    i work remotely but i am told that all standard inline forms have worked without issue. quick and dirty remedy for backwards compatibility is to create dummy collision detection module and life is good.
  • freak
    17
    • January 11, 2022 at 10:02 PM
    Could it be that the inlineform is older than 8.3 and because of this the inlineform does not work?
    I try tomorrow to change on 8.3 once and then load to 8.5.
  • the leg
    643
    • January 18, 2022 at 2:34 PM
    Very odd i went from krc2 V4.1.7 to V8.3.3 with no issues
    Have you tried running the software installer again with the Programs installed and letting KSS upgrade them
    D:\KRC_Release\setup.exe
  • MOM
    175
    7
    1,419
    • January 19, 2022 at 1:35 AM
    as I rember there are three ways to get an inline form:
    - UserTech
    - ExpertTech
    - TP with inline form programmed in a dll
    Therefore a KrcDiag (if possible) or the exact way on how to reproduce the problem would be helpful.
    Another important question:
    what is the exact KSS version (KSS 8.3 just tell the family and not the person like KSS 8.3.39)
Similar Threads
  • kuka configuration in Tia portal
    • Vasya Kazmin
    • August 29, 2020 at 8:34 PM
    • KUKA Robot Forum
  • EL6695-1001 to Beckhoff PLC
    • Dp18
    • April 22, 2021 at 6:14 AM
    • KUKA Robot Forum
  • [KUKA] KRC <8.3 InlineForm point Conversion to KRC 8.5 and newer
    • freak
    • January 3, 2022 at 9:04 AM
    • KUKA Robot Forum
  • Ethernet Comunication with Allen Bradley PLC
    • jcarlson
    • November 4, 2021 at 6:26 PM
    • Fanuc Robot Forum
  • How to get a data type of REAL from PLC to robot?
    • knowledgesharing
    • September 19, 2014 at 11:44 AM
    • KUKA Robot Forum
  • Absolute Accuracy Info KRC2 - KRC4
    • Razzzhead
    • November 16, 2020 at 8:33 PM
    • KUKA Robot Forum
  • Program to manage CAD to PATH data (convert Cartesian to Joint Values) FANUC
    • RoboDrillx
    • September 24, 2020 at 6:44 PM
    • Fanuc Robot Forum
  • movement of kuka
    • jjf
    • October 31, 2018 at 2:28 PM
    • KUKA Robot Forum
  • camera's coordinates to pick object
    • sudan
    • April 26, 2018 at 12:15 PM
    • KUKA Robot Forum
