Some questions about making a mobile controlled robot
  • Hello, I'm trying to make a mobile controlled robot without microcontroller for my Diploma Final Year Project. But I am facing problem regarding DTMF Module. When I connect the battery to its respective pins I am getting RANDOM outputs at pin no 11,12,13,14 and 15. So can you help me to come out of this problem. ( once i have discharged all the capacitors and tried again but same problem occurs again )
    And I also wanted to know the connection of AUX Cable in the circuit.
  • kwakisaki
    Approved the thread.
  • :question_mark: :question_mark:
    You should not tell us which circuit you don't use, but which circuit you use.
    You didn't provide any information about what hardware you are using.
    Which DTMF module?
    Pins 11,12,13,14,15 of what?
