How to set up a used robot from scratch..
  • eliasgr
  • December 27, 2021 at 4:30 PM
    Fubini
    282
    1,903
    • December 29, 2021 at 9:22 AM
    • #21
    Windows image from KUKA is not only a standard Windows but already contains non standard software needed to run a KSS on top. This among other stuff includes the robots realtime os VxWorks the needed user accounts for VxWorks and necessary device drivers. So to get back to the complete factory default also reinstalling kuka windows is needed. But sometimes it is sufficient to reinstall kss as mentioned above. You could try it. I am not sure this is sufficient for safe operation. Before doing this you should of course check whether all needed installers for add-ons like safe robot are available. Just in case having the needed windows images never hurts. This is stuff the seller should always provide (but honestly often is not included 😈). In that case you can always contact Kuka. If you provide the robot serial number and there exists a valid license for the respective addon they are happy to send you the software.
    Fubini
  • eliasgr
    41
    • December 30, 2021 at 11:05 PM
    • #22
    Ok I think I understand
    Honestly I would have never guess Robots would be that complicated ,of course once you learn ,everything is easy.
    Now I prepared the X11 service jumper plug as per kuka manual ,but what is the safeguard connection about ? pin7 to pin25
    thanks
    Elias
    panic mode
    1,294
    13,126
    • December 30, 2021 at 11:32 PM
    • #23
    there is bunch of X11 pinouts out there. you need to use correct connection diagram for your controller type.
  • eliasgr
    41
    • December 31, 2021 at 12:15 AM
    • #24
    I got it from kuka manual on ED05 ,there is only one diagram for X11 there
    How to determine mine particular X11 diagram?
    thnx
    Elias
    Files
    book.book.pdf 279.62 kB – 37 Downloads
  • eliasgr
    41
    • December 31, 2021 at 12:16 AM
    • #25
    Files
    X11 service jumper.pdf 225.67 kB – 34 Downloads
  • eliasgr
    41
    • January 18, 2022 at 11:18 PM
    • #26
    hello
    Did some progress here .I made the jumper plugs for x11 and x40 and thanks to the help of a good friend we managed to log in as maintenance safety by resetting the pass to default and uninstall profibus and get rid of most of the errors.
    Also cancelled monitoring all axes from safety parameters ,but there is no global settings line to cancel safe robot.
    The errors now are.
    436 short cirquit braking request by RDC 1
    411 safety mode not possible
    390 mastering test req
    437 calibration reference sw defect
    444 failuresafety output no 3
    403 Estop safety controler
    310 safety cirquit drives not ready
    200 drives contactor off
    Checked kuka safe operation manual about 444
    please look at pic at n3 ,what does the description mean?
    Any suggestions what to do ?
    thanks
    Images
      • 39.92 kB
      • 819 × 559
      • 13
    SkyeFire
    1,060
    9,456
    • January 19, 2022 at 12:03 AM
    • #27
    Quote from eliasgr
    The errors now are.
    463 is a second-order effect of the other errors.
    411 is caused by 390
    437 means that the Mastering Reference Switch is not connected. Unless you can deactivate
    SafeOperation entirely, you may have to resolve this in hardware.
    444 is concerning. It suggests a hardware issue with the SafeRDC, or the X40 connector. I would check the wires related to Safe Output 3 and make sure there are no shorts or cross connections. Also, open the Safe Diagnostic menu and check the Output Status.
    403 is a secondary effect, like 463.
    310 is a secondary effect.
    200 is just a status message.
    panic mode
    1,294
    13,126
    • January 19, 2022 at 1:42 AM
    • #28
    X444 suggests that RDC is unhappy. check wiring of your safety plug X40
  • eliasgr
    41
    • January 21, 2022 at 9:45 PM
    • #29
    I was concentrated at 444 also. i must contact KUKA for the correct x40 plug and try egain.
    Thank you for the help
  • vvelikov
    486
    • January 22, 2022 at 4:55 PM
    • #30
    The X40 wiring is here in the forum - check the
    Manuals, Software and Tools for KUKA Robots
    - it is in the head of the KUKA forum
    In the docs, provided with your robot (usually behind the PC on the cabinet door) you can find specifically your robot config and in outs for safety.
  • eliasgr
    41
    • January 23, 2022 at 10:06 AM
    • #31
    Yes I have found this wiring diagram from the forum for X40,
    unfortunately I still have theese errors after making the X40 jumper plug
    There are at least 3 examples of X40 wiring at manual safe operation 2.1 .I will try them and see if one of them changes anything.
    But my questions is should I be looking at X41 plug since the explanation of error 444 is about x41 ,please look at atached pic above ,and what should I look for at X41 ? what test to make ?
  • vvelikov
    486
    • January 23, 2022 at 1:11 PM
    • #32
    Hi, you should have also data cable X21.1 – X41 connected
  • eliasgr
    41
    • January 23, 2022 at 8:27 PM
    • #33
    yes it's connected
  • eliasgr
    41
    • January 30, 2022 at 9:11 PM
    • #34
    Got a polite reply from KUKA saying that they are not helping non trained persons to operate Robots ,and case closed ! I cant imagine every time there is an error I have to bring a trained person ,the closest kuka technician is 500km away and he suggested me to sent the robot to their premises in order to make it functional ! not to mention the $$$ they asked for !!
    I checked wiring one by one on X41 is all good
    the thing that makes me scratch my head is that my functional X40 plug as came with the robot had no wiring at B8 and B9 positions ,I had to relocate some spare ones from D section.
    So I'm wondering what I'm I bridging at those positions as per X40 diagram since the robot was operating without circuit there ,or maybe I'm missing something ?
    Got the Robo blues..
    panic mode
    1,294
    13,126
    • January 30, 2022 at 9:55 PM
    • #35
    soo.... what was the question?
    i can see their response to be fitting if you said something like" "i never operated robot, never got any training but simply want to do some wiring in the safety circuit and run the robot, can you help?".
    also a good thing when buying used robot (or car or airplane or submarine) is to check if it works, if it has any problems (squealing sound, oil leaks, signs of wear or damage) and if it includes documentation.
    when all if good, then buy it... if not, make the offer conditional and give them the chance to remedy the problem. don't buy it if not in good order...
    when one gets robot that "used to work" but it does not work now, it is much harder to get it operational. worse you don't have contacts and resources to do needed repairs and from someone diving in head first like that it could be seen as a red flag and may not want to get involved with someone not serious.
    As for training, why don't you get trained or have one of colleagues/employees trained? That would clear that up.
    Quote from eliasgr
    Well... i don't want to discourage you but you would not believe how many times i have heard that, only to find out that things were not done correctly. Maybe post circuit you tried to follow along with picture of implementation. Than at least we may be able to comment if this is still looking fine or not.
    and, did you say X41? or do you mean X40?
    Don't recall last time i saw KRC2 but here is X40 jumper plug that used to work for me.
    finally, do all things look original or there is suspicion that alterations were performed?
  • eliasgr
    41
    • January 30, 2022 at 11:24 PM
    • #36
    Quote from panic mode
    Lol , you got it correct , yes I'm direct and say the truth always ,no beggin and no lies.
    Of course the result not always satisfying :-((
    The robot is in mint condition , any one operating machines for some time can tell ,and I did make sure I got a really good deal because it was not possible to demo.
    That dont mean it might not have a couple of things to solve. Only thing needed is guidance
    I have ,operated and serviced expensive and complicated machines for more than 20 years , never had a service man by the phone or mail check my training certificate first before providing help.I can understand KUKAs concern about people ''playing'' with dangerous robot ''toys'' but that is not the case with all and a CNC lathe ,mill ,Laser or Punching machine is not leess dangerous than a robot if in wrong hands ,you dont need training for having common sense.
    anyways ,no hard feelings
    Edited once, last by eliasgr (January 30, 2022 at 11:35 PM).
  • eliasgr
    41
    • January 30, 2022 at 11:32 PM
    • #37
    Yes checked X41s cable continuity from one side to other
    also checked x40 plug as per drawing at least a dozen times
    Will post pics about plug
    Not all things look original ,X41 position used to be in other place ,was about to comment that looked suspicious.. will post pics about that too
    Diagram is same as you showing but pic on the left is upside down ,right ??
    Thank you for all the help
    Edited once, last by eliasgr (January 30, 2022 at 11:38 PM).
  • eliasgr
    41
    • January 30, 2022 at 11:50 PM
    • #38
    Please look at output N3 in the picture from KUKA manual
    I think it clearly says I should look at X41right ? or ..?
    And if I should look at X41 ,what kind of test should I perform ?
    anyone have an idea?
    thank you
    Images
      • 39.92 kB
      • 819 × 559
      • 12
    panic mode
    1,294
    13,126
    • January 31, 2022 at 12:02 AM
    • #39
    you lost me. i do not see anything called N3. maybe i am blind...
    panic mode
    1,294
    13,126
    • January 31, 2022 at 12:22 AM
    • #40
    Quote from eliasgr
    you are focusing on wrong things. picture was placed upside down so that contact numbers are easier to read, you can rotate the image and compare. besides, there is clearly marked order of inserts (A,B,,,,C,D) and coding pins match.
    btw, your connector X40 is not a standalone plug, there is a strain relief and cable going somewhere... this circuit need to be completed.
    the X40 jumper plug is self contained, and all circuits are completed (bypassed), so there are no external cables.
    this is an important detail and you need to check that cable and documentation to see what is going on there and it is complete. jumper plug is used to bypass all this when no safe operation is used or to test if everything is ok with the robot (by ignoring external circuit). in your case that external circuit is present but nobody knows if and what is connected to it.
    Quote from eliasgr
    well, if you did, good for you but i certainly have my doubts... how exactly did you test it? visually? using multimeter? using x-ray?
