  4. ABB Robot Forum
Robot Task is not Executing
  • gmumaugh
  • December 20, 2021 at 4:29 PM
  • gmumaugh
    62
    I am having an issue on an IRB7600 where my main T_ROB1 task will not execute. I am able to jog, but then say for example I try to return home by running PP to main, when I hit play I hear the brakes disengage, but the program does not run even a single line of code. The status never changes to say "Running", but no faults ever occur.
    It isn't just a problem with the main program though, I can't run any routine within T_ROB1. I have four other tasks that are all running fine, but they are just for background logic. I'm using RobotWare version 6.12.00.00 and IFWC version 6.08.0134.05. These are the exact same versions and systems I've used in other robots I've set up, because there is a standard template that I load into every ABB robot I work on, yet this is the only one that I have had this issue with.
    The system has roughly 224MB of free RAM, and I also tried using a different FlexPendant. The robot was able to execute the main program and auto-home itself with the new pendant, but then later in the day the issue randomly came back. There are two robot outputs from IFWC that I'm getting but don't know the root cause of: doSYS_Error and doSYS_MiscError.
  • Lemster68
    295
    2,454
    Blog Articles
    7
    • December 20, 2021 at 5:16 PM
    There may be a stopmove active from one of the background tasks.
Similar Threads
  • Adding positions to a que
    • Nortech
    • July 5, 2021 at 5:54 AM
    • ABB Robot Forum
  • Pulse command
    • ericwiz7923
    • December 21, 2020 at 3:19 PM
    • Kawasaki Robot Forum
  • RJ3 + Lack of Background Task Capability
    • MMCINTIRE
    • February 4, 2020 at 3:08 PM
    • Fanuc Robot Forum
  • macro execution
    • KalebM
    • December 13, 2019 at 7:49 PM
    • Fanuc Robot Forum
  • How to KILL a task and RESET the cell ?
    • Ayoub
    • November 27, 2019 at 6:06 PM
    • KUKA Robot Forum
  • Power_ON routine no longer executing on boot
    • SkyeFire
    • October 9, 2019 at 5:47 PM
    • ABB Robot Forum
  • Changing velocity via process data in the background task.
    • uc2kah
    • September 25, 2018 at 5:01 PM
    • KUKA LBR IIWA
  • Test mode problem S4 IRB1400
    • karubot
    • December 4, 2018 at 2:21 PM
    • ABB Robot Forum
  • Creating a HMI in the Teach Pendant
    • Miguel_LG
    • April 20, 2018 at 11:56 AM
    • Fanuc Robot Forum
  • Routine
  • IRB 7600
  • IFWC
  • Framework
  • Task
