Dynamically Changing TCP for Milling Operations
  • Hello,
    I am trying to dynamically change the TCP of our spindle to be along the bit based on a specified cut depth. We have software that is sending XYZABC coordinates that are normal to the surface we are attempting to mill and we are wanting a pocket cut that follows the shape. If we are able to move the TCP by 1/2 an inch up, we should be able to do this successfully, however when running this code, it does not use the new calculated TCP but rather the one saved in TOOL_DATA[9].
    I'm honestly not sure where the error in this is as my program compiles correctly and when I attempt to debug and monitor my millingOffsetTCP values, they are populated correctly, the motion is just using the wrong tool. I am currently running KSS 8.5.8 on a KUKA KRC4 controller, and any help would be much appreciated! Thank you and have a good day.
