Dear Member
I use the Kladder for programming the sequence with the spot welding assembly line in an automotive factory.
when I use the monitor function for monitoring the ladder diagram the program has an error that appears as "Kladder communication error.(m)".
some time can monitor but many times have the problem cannot monitor anymore.
if someone has a solution about setting up for regarding the issue.
please advise and thank you in advance.
