Couple simple questions about basic editing and playback.
  • Nddwind
  • December 11, 2021 at 2:26 AM
  • Nddwind
    18
    Hello, I had a couple simple questions that I couldn't seem to find the answers to in the manuals.
    How do I insert a blank line in an existing program that I can later go back and add to.
    Also, is there a way to weld from the teach pendant? When Im running the program from the pendant I hold down and interlock and test start but the arc on commands appear to be ignored.
    I'm using a AR1440 manipulator with a YRC1000 controller.
    Sorry for the dumb questions, I have zero experience with yaskawa/motoman and come from a fanuc background.
  • 95devils
    229
    8
    1,930
    • December 11, 2021 at 2:32 AM
    You can not insert a blank line. You can insert a comment with a space to replicate a blank line.
    Press the WELD On/Off button. Left hand side of the pendant. This will give you weld in teach during Interlock+Test Start.
  • 5GensOfFun
    51
    • December 11, 2021 at 3:17 AM
    Quote from 95devils
    95devils is correct, however you may also need to be in Management mode to weld manually. This is often standard, we usually change the CIO on our systems to allow in Edit mode too.
  • Nddwind
    18
    • December 11, 2021 at 11:34 AM
    Thank you gentlemen
  • Nddwind
    18
    • December 11, 2021 at 11:09 PM
    weld button was lit and interlock plus test start did not initiate the weld. You mentioned that I may have to be in management mode, unsure how to achieve this.
    I did log into an administrator account but I'm not sure what permissions it has or even how to check that out
  • vmec
    7
    41
    • December 12, 2021 at 2:56 AM
    Changing users (modes) is under SYSTEM INFO->SECURITY.
    Management mode password is all 9999s.
  • Nddwind
    18
    • December 12, 2021 at 5:07 PM
    thanks
