- Here is the job we are having problems with. As I said, it's losing track of where it's at in a pile of slip sheets and tries to get to the bottom. If it does get to the bottom, it will pick up the sheet just fine. However, if we stack them high (as they should be), the robot will pick up maybe a couple then slam into the pile and the Servo Tracking Error L & B populates. I can see in the code that the robot is supposed to search for the slip sheets until Input X goes high, then afterwards, it's supposed to store that position. To me, that's where the problem is stemming from. The robot should be storing the location but it's not. When it comes back to get the next slip sheet, it's going to the bottom of the stack instead of the last pickup place. If anyone could help me I would appreciate it.
/JOB
//NAME S1SSPK
//POS
///NPOS 2,0,0,6,0,0
///TOOL 0
///POSTYPE PULSE
///PULSE
C00000=252316,49442,-37418,0,37939,-41371
C00001=238349,38429,-33484,0,31177,-36751
///TOOL 1
///POSTYPE BASE
///RECTAN
///RCONF 1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
P00101=0.000,0.000,100.000,0.0000,0.0000,0.0000
///TOOL 0
///POSTYPE PULSE
///PULSE
P00120=164210,-31801,-72994,0,12837,-43462
///POSTYPE BASE
///RECTAN
P00121=-1414.679,140.000,-145.000,179.9979,0.0002,89.2000
P00122=-1414.679,140.000,-1045.000,179.9979,0.0002,89.2000
///TOOL 1
P00123=-1414.686,140.001,-695.627,179.9985,0.0001,89.1999
///TOOL 0
P00124=-1414.679,140.000,-145.000,179.9979,0.0002,89.2000
//INST
///DATE 2015/07/11 10:56
///ATTR SC,RW
///GROUP1 RB1
///LVARS 6,1,8,0,0,0,0,0
NOP
' PICK SLIP SHEET
' Store in cube 64 output
SPEED VJ=27.50 V=275.0
DIN LB000 SOUT#(120)
CALL JOB:AUTOHOME IF LB000=0
' Slip sheet pick pounce position
MOVJ P120
'Turn on picking ss to plc
DOUT OT#(78) ON
' Wait for slip sheet OK
WHILE IN#(65)=OFF
RET IF IN#(41)=ON
RET IF IN#(85)=ON
ENDWHILE
' Set start position
' Set start position equal to
' end position
SET P121 P122
' Extract current Z value
GETE LD001 P121 (3)
' Add in offset amount
SET LD001 EXPRESS LD001 + 900000
' Store new Z value
SETE P121 (3) LD001
' Set incremental position
' Set position equal to zero
SUB P101 P101
' Store Z increment
SETE P101 (3) 75000
' Set depart position
' Set depart position equal to
' end position
SET P124 P122
GETE LD001 P124 (3)
' Store new Z value
SETE P124 (3) LD001
*RETRY
' Turn on vacuum
CALL JOB:VAC_OFF
' Turn on solenoid to limit vac
DOUT OT#(21) ON
' Slip sheet start position
MOVJ P121 PL=1
' Turn on vacuum
CALL JOB:VAC_ON
DOUT OT#(21) ON
' Check for fast search
IFTHEN IN#(2045)=ON
' Move to last found position
MOVL P123
ENDIF
' Search for slip sheet
MOVL P122 V=20.0 UNTIL IN#(3)=ON
SETE P101 (3) 0
' Move away
DOUT OT#(21) OFF
IMOV P101 V=75.0 PL=0
' Store last found position
GETS PX123 $PX000
' Convert last found position
CNVRT PX123 PX123 BF
GETE LD001 P123 (3)
SET LD001 EXPRESS LD001 + 100000
' Store new Z value
SETE P123 (3) LD001
SETE P101 (3) 100000
' Move away
IMOV P101 V=50.0 PL=0
' Check slip sheet present
IFTHEN IG#(1)=0
' Increment retry count
ADD LB005 1
' Retry 3 times
IFTHEN LB005<=3
JUMP *RETRY
ENDIF
CALL JOB:CHK4SS
ENDIF
'Turn off picking ss to plc
DOUT OT#(78) OFF
' Slip sheet pick depart
MOVL C00000 V=500.0
TIMER T=0.50
MOVL C00001 V=500.0
CALL JOB:CHK4SS IF IN#(3)=OFF
' Set part held
SET I119 11
' Set OK for fast search
PULSE OT#(2029)
MOVJ P120
END
cat91345
- Smilies
- Attachments
- Settings
abbAlarmBackupCommunicationConfigurationDeviceNETdx100dx200errorEthernetethernet/ipexternal axisFanucFanuc 30ibhelphmiI/Oiiwairc5IRVIsionkarelkawasakikrc1KRC2KRC4KRLKUKAmotomanMotosimNX100PLCpositionPROFINETProgramProgrammingrobodkroboguiderobotrobotstudioRSIsafetySPEEDtcpTCP/IPteach pendantvisionWeldingworkvisualyaskawaYRC1000
Fanuc/ ABB Robotics Engineer wanted
CASmitt Nov 19th 2021
How to see your Job Posting (search or recruit) here in Robot-Forum.com
Werner Hampel Nov 18th 2021
Share
Similar Threads
- Prof.Yeager
- Mar 27th 2013
R-axis Alarm 4328
- jeemax
- Apr 7th 2020
Motoman Home Position Tool
- JankyPLC
- Jul 24th 2019
Motoman motor /encoder Ruined?
- SPLights
- Aug 14th 2019
Servo Tracking (again)
- aut8126
- Aug 21st 2019
ERC ROBOT SERVO TRACKIN ERROR ISSUE
- vib_tripathi149
- Nov 16th 2018
Problem with B axis
- Camilo Nievas
- Oct 30th 2018
ABNORMAL SERVO TRACKING[Error Code: E0021]
- sonaldhake
- Dec 25th 2017
Powered by WoltLab Suite™ 5.3.15
