Converting INT to ... REAL?
  • panic mode
  • December 6, 2021 at 3:42 PM
    panic mode
    1,278
    13,079
    got another PM from lost soul joined forum and does not know how to use it
    Quote
    Hello panic mode first of all im sorry to send you this question directly, but i couldn't find how to send the question into forum.
    The program number is sent to the robot as an integer from the PLC.
    Is it possible to convert integer values to enum?
    There is conversion from unum to int in the forum. However, I could not find the conversion from int to enum.
    posting in forum could not be easier. navigate to desired forum, then click on big button on the top of the page that says "+ CREATE THREAD"
    what kind of robot?
    not sure what unum is but integer to enum is easy using lookup table.
    conversion to/from INT was covered several times with examples. use forum search.
  • panic mode December 6, 2021 at 3:52 PM
    Changed the title of the thread from “Converting INT to REAL” to “Converting INT to ... REAL?”.
Similar Threads
  • Convert real to int
    • SimotionD410
    • August 20, 2018 at 12:28 PM
    • KUKA Robot Forum
  • Real Time external control of Kuka using RSI
    • geraldft
    • May 8, 2020 at 7:57 AM
    • KUKA Robot Forum
  • Ktrans Rj2 GET_TPE_PRM issue
    • aroldino
    • August 4, 2020 at 1:50 PM
    • Fanuc Robot Forum
  • Converting STRING to REAL
    • dyu
    • September 25, 2021 at 4:35 PM
    • Fanuc Robot Forum
  • Real number value *.0 can't be passed trought procedure CALL as real just as integer
    • fmiroslav
    • June 28, 2021 at 10:51 AM
    • Fanuc Robot Forum
  • Bizarre GET_REG behavior
    • SkyeFire
    • October 26, 2020 at 7:12 PM
    • Fanuc Robot Forum
  • KUKA CONVEYOR TECH, $SEN_PREA
    • Evstahi
    • September 8, 2020 at 3:03 PM
    • KUKA Robot Forum
  • Roboguide-converting old file to new
    • TuckerJPhillips
    • December 17, 2019 at 4:33 PM
    • Fanuc Robot Forum
  • new to kuka
    • Dbonds28
    • July 2, 2018 at 4:05 PM
    • KUKA Robot Forum
  • Mapping Low Byte and High Byte to integer and/or decimal
    • debjitghosh
    • September 11, 2018 at 3:36 AM
    • KUKA Robot Forum
