serial comunication krc2
  • m.dinio
  • December 4, 2021 at 9:20 PM
  • m.dinio
    61
    hello dears,
    i'm new in krl.
    please help me to start with serial comunication on krc2.
    how to open COM2 and send and receive data to another pc.
    may you send simple example program.
    thanks alot
    SkyeFire
    1,038
    9,371
    • December 5, 2021 at 2:05 AM
    • Best Answer
    Depends on what generation KRC2, and what KSS version it's running.
    I have an old example program for KSS 5 (KRC2 ed2005) at http://kuka.skyefire.org/
    But you would also have to configure the serial port in... HW.INF, if I recall correctly.
    ed2005 KRC2s used COM3. I think the pre-2005 models used COM2.
    MOM
    175
    7
    1,418
    • December 7, 2021 at 12:11 AM
    it also depends on the protocol you want to use
    - for sensor communication you want to use the 3964r protocol (it is like tcp)
    - for other communication you want to use XON/XOFF (it is like udp)
    Question: what is your goal?
  • m.dinio
    61
    • December 7, 2021 at 9:44 AM
    thanks for your response.
    i want to use this protocol for sensor communication (gripper and conveyor sensors )
    SkyeFire
    1,038
    9,371
    • December 7, 2021 at 4:54 PM
    You still didn't mention what generation KRC2 you're using.
    Dug out some old backup files. These are from ed2005s, running KSS 5.4:
    HW_INF.INI:
    [SERIAL]
    ;ENABLE:  COM is accessible by robot (vxWorks)
    ;DISABLE: COM is accessible by Win95
    ;CONSOLE: for developer only
    COM3=ENABLE    ;[ENABLE, DISABLE, CONSOLE]
    SERIAL.INI contains the settings for the serial port: baud rate, protocol, parity, etc.
    ; SERIAL.INI
    ; Configuration of the serial ports and their protocols
    ; Lindemann 27.02.2002 KUKA Controls:
    ;           update comments and COM4 removed
    ; Lindemann/Scheffold 25.10.2002 KUKA Controls:
    ;           XONXOFF: DSR signal now setable
    ; Protocol description:
    ; 3964R    Standard software protocol  (Siemens)
    ; SRVT     Servo Robot Vision Telegram (use only with Servo Robot)
    ; WTC      Spot Weld Controller        (use only with Weltronic Controler)
    ; XONXOFF  Xon/Xoff software protocol  (use also as pure serial communication)
    [COM1]
    BAUD=9600
    CHAR_LEN=8   ; 7,8
    STOP_BIT=1   ; 1,2  at time not changeable
    PARITY=2     ; EVEN=2, ODD=1, NONE=0
    PROC=1       ; 3964R=1, SRVT=2, WTC=3, XONXOFF=4
    [COM2]
    BAUD=9600
    CHAR_LEN=8   ; 7,8
    [COM3]
    BAUD=9600
    CHAR_LEN=8   ; 7,8
    [3964R]
    CHAR_TIMEOUT=500   ; msec
    QUITT_TIMEOUT=500  ; msec
    TRANS_TIMEOUT=2000 ; msec
    MAX_TX_BUFFER=2      ; 1..5         number of send buffers
    MAX_RX_BUFFER=10     ; 1..20        number of receive buffers
    SIZE_RX_BUFFER=100   ; 1..2048      size of receive buffers
    PROTOCOL_PRIOR=1     ; HIGH=1, LOW=0
    [SRVT]
    CHAR_TIMEOUT=200     ; msec
    MAX_RX_BUFFER=2      ; 1..20
    [WTC]
    SIZE_RX_BUFFER=50    ; 1..2048
    [XONXOFF]
    CHAR_TIMEOUT=50      ; msec   Timeout after last received character
                         ;        to recognize the end of telegram
    SIZE_RX_BUFFER=100   ; 1..2048 longest expected telegram length + 15 characters
    XON_VAL=17           ; 0..255  XON  character (decimal)
    XOFF_VAL=19          ; 0..255  XOFF character (decimal)
                         ; if XON_VAL=0 and XOFF_VAL=0 then XON/XOFF protocol
                         ; is disabled (pure serial communication)
    DSR_LINE=0           ; 0 = DSR line not connected, 1 = DSR line must be high
    [TEST]
    ;testprint (Rx/Tx-telegrams) on telnet if value > 0
    TESTPRINT=0
    [END SECTION]
    The CWRITE manual contains some information on serial port config.
    Files
    CreadCwrite_54_55_57.pdf 807.69 kB – 41 Downloads
  • mehrandinio
    7
    • December 8, 2021 at 5:43 PM
    I configured serial.ini with xonxoff proc and comminucation is good .
    But when i change proc to 3649R and send data to laptop i receive 02 02 02 02 15 assci . :thinking_face:
  • hermann
    403
    2,593
    • December 9, 2021 at 9:38 AM
    Search web for 3964r (not 3649 !) protocol, and you will see why. The protocol needs specific answers for every sent data.
    There are plenty of informations in the web.
    MOM
    175
    7
    1,418
    • December 9, 2021 at 11:03 AM
    Quote from mehrandinio
    This is actually STX STX STX STX NAK
    The KRC is sending STX in order to start the communication.
    Your other PC is not responding in the specified time and the KRC repeats STX.
    After 3 retrys the KRC stops to send the request and sends NAK
Similar Threads
  • KR2 kss 4.1.4 serial comunication reads but doesn't write
    • jore731
    • June 26, 2018 at 10:49 AM
    • KUKA Robot Forum
  • serial
  • comunication
