KRC2 HDD fail
  • mbalazs
  • December 3, 2021 at 11:01 AM
  • mbalazs
    25
    I need support.
    Setup: (v)KRC2 converted to KRC2 . KSS 5.2.x . Two extra 512 MB RAM installed ( if I remember correctly, then its different type than the original).
    Situation: I installed the robot/krc2 a few months ago in an industrial setting. It is used for milling. There are 80+kW motors for other machines on the same main line. There are voltage drops when they start. I have installed a Kemet filter before the VFD of the spindle, but I understood that the KRC2 has built in filters, so I haven't installed one up to it. Three weeks ago I had a HDD fail. The HDD got completely destroyed, I couldn't recover the data. I had backup and installed a second hand old HDD. It worked fine until this also broke. When I checked on the KCP there was an install image. I have kept the KSS installer USB plugged in and it seems it restarted into that when the HDD failed. I took out the USB and restarted the KRC. It said NTLDR is missing. Checked the USB in my laptop and it didn't show up on the drives list. I can't read data from it but I can see it in device manager. Also the two times that this happened I had really large .SRC loaded into memory. First HDD failed during runtime of the program and the second failed after finishing the program but not canceling it and staying that way for a few days. I have made the pagefile registry tweak so I can load larger files into memory. Visually the motherboard and KRC2 internals look good. No dust, dirt, I can't see swollen/damaged capacitors. It looks OK.
    I am on the way to setting up a new HDD. I would like to keep this one healthy.
    How could I make this system more robust?
    What are the steps I should take from a preventive maintenance standpoint?
    What would be the most likely culprit that I can start to troubleshoot?
    I am grateful for any help that you can offer.
  • the leg
    643
    • December 3, 2021 at 3:05 PM
    How old where the hard drives ? maybe buy a new hard drive and install in on that then take an image so you can recover quickly . I assume its a non ed05 that you have upgraded
  • DannyDJ
    67
    503
    • December 3, 2021 at 8:56 PM
    For krc2's i use Flash Disk Module (DOM's) instead of old IDE hard drives.
    DOM's are faster, cheap and durable.
    Images
      • 72.77 kB
      • 953 × 1,200
      • 25
    MOM
    175
    7
    1,424
    • December 3, 2021 at 11:47 PM
    Quote from mbalazs
    Check why you had the problem with the old ones:
    1. clone the hard drive sector based instead of file based
    sector based copy
    file based copy
    Difference:
    sector based:
    1:1 copy of your hard drive with all problems (time consumed: about 60 min)
    file based:
    while copying all files will be defragmented and most of the time lost clusters are found (chkdisk) and fixed (about 30 min)
    will be cont ...
  • mbalazs
    25
    • December 9, 2021 at 10:45 AM
    Quote from the leg
    Old. Both of them. I have bought a 30 GbTranscend PATA SSD. It is an ed05.
    Quote from MOM
    sector based copy
    file based copy
    Difference:
    sector based:
    file based:
    will be cont ...
    I am trying to install Windows but I ran into several problems. Everytime, no matter what HDD, it fails when factory -winpe starts and it gets to "Formatting and partitioning drives" . I have tried to manually extract .cab and run it that way, but it says "Operating system not found". I have extracted the .cab file to the previous wiped HDD and Windows installation loading screen appears, but gets stuck after a while and I am forced to shut down. I guess the wiped HDD still had a matching MBR but has other problems. Could be something totally different. I have also tried swapping RAM, but it seems the RAM modules are fine.
    I will be trying sector cloning.
    Please share if you have any ideas.
    Thanks The LEG(nice arm you got there;), DannyDJ and last but not the least, thanks MOM! :smiling_face:
  • hermann
    407
    2,615
    • December 9, 2021 at 12:58 PM
    My suggestion is the mainboard. Even if you don't see defective capacitors, if every Harddisk makes problems, the reason isn't the hdd.
    Or the install files are corrupt.
  • mbalazs
    25
    • December 9, 2021 at 1:18 PM
    Thank you Hermann.
    I am currently installing winpe. I've got the SSD to work after a cluster clone of the defective HDD and extracting the WinXP.cab on it. I've also changed the MBR to work with WinXP machines in the software AOMEI. I hope this helps someone. Also it is of importance to jumper the ssd or hdd to master.
    It seems the second HDD got some bad sectors and broke down.
    Next would be to find the bugs that fry the HDD s and get rid of them. I suspect its the voltage/current fluctuations somehow get to the HDDs.
    Could it be that I have a DevNet module connected to the MFC and the Devnet module gets the power from a 24 DC supply connected to one of the 220 V lines coming from the mains filter?
    Or maybe its just pure coincidence that the old HDDs are giving up and one of the USBs got fried. Bare in mind that when the HDDs got fried the system rebooted into the USB windows setup and stayed in it for a day.
    Edited once, last by mbalazs (December 9, 2021 at 1:25 PM).
    MOM
    175
    7
    1,424
    • December 9, 2021 at 2:02 PM
    ok,
    problems I encountered in the past:
    - jumper settings
    - ribbon cable
    - vibrations (e.g. pc fan)
    - virus
    in order to find the problem my post #4 should helpful
  • the leg
    643
    • December 12, 2021 at 4:28 PM
    do a fresh install with only video card and MFC installed unplug any devnet cables
  • ali rahmani
    10
    • November 7, 2024 at 4:40 AM
    Hello friends, I have a problem in using hard dom for kuka krc2 robots. My problem is that I just got the dom hard drive, and I was able to put the image on it, but when I connected it to the robot motherboard. It cannot run the image and I tested both in master and slave mode. Please guide me how to connect this dom hard disk to the robot so that it can run the image. Does it need a special connector or does it have a special image software? Please help, thank you very much
    SkyeFire
    1,052
    9,431
    • November 7, 2024 at 3:54 PM
    • #11
    Quote from ali rahmani
    Do not spam multiple threads with the same posts.
Similar Threads
  • What is KRC2 doing when you set an array of frame equal to a single frame?
    • mjnewsum
    • February 22, 2021 at 10:00 PM
    • KUKA Robot Forum
  • [SOLVED] KUKA KRC2 Windows fail
    • Nox
    • January 16, 2019 at 10:30 AM
    • KUKA Robot Forum
