Hi all,
we keep getting this error when robot is pickin up slip sheets. The robot will only pick these up in area about 6 inches or else this errror will show up. I have checked all cables. What can this possibly be?
Hi all,
It could be:
1) Posture problem
2) Near a singularity point
3) If the robot is old: lack of grease or cable problem
4) Too much grease(if you have done a recharge)
5) Servopack
6) Tool not defined nor calibrated
7) etc...
I think Servo Tracking Error is the one you will get if the robot crashes.
Is the path being offset by a sensor or perhaps with some math?
The robot is losing track of where it’s at in a pile of slip sheets. It will pick one up, it’s then supposed to record where it picked that one up, store the location , then return to that location for the next slip sheet minus a small offset. What’s happening is the robot is slamming into the pile and this error populates. I’ve looked at the variables it’s supposed to record the last position in, and it never changes. Should the position variable be different on the next pickup ?
What’s happening is the robot is slamming into the pile and this error populates. ?
So why you in the first post you ask the reason of you errors: you get a servo track if you slam the robot .
How do you calculate your offset, how do you pass your shift to the variable?
if you can post your code maybe someone could have a look?
There are tons of program solution to your problem but I don't know the one your're trying.
Here is the job we are having problems with. As i said, it's losing track of where it's at in a pile of slip sheets and tries to get to the bottom. If it does get to the bottom, it will pick up the sheet just fine. However, if we stack them high (as they should be), the robot will pick up maybe a couple then slam into the pile and the Servo Tracking Error L & B populates.
/JOB
//NAME S1SSPK
//POS
///NPOS 2,0,0,6,0,0
///TOOL 0
///POSTYPE PULSE
///PULSE
C00000=252316,49442,-37418,0,37939,-41371
C00001=238349,38429,-33484,0,31177,-36751
///TOOL 1
///POSTYPE BASE
///RECTAN
///RCONF 1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
P00101=0.000,0.000,100.000,0.0000,0.0000,0.0000
///TOOL 0
///POSTYPE PULSE
///PULSE
P00120=164210,-31801,-72994,0,12837,-43462
///POSTYPE BASE
///RECTAN
P00121=-1414.679,140.000,-145.000,179.9979,0.0002,89.2000
P00122=-1414.679,140.000,-1045.000,179.9979,0.0002,89.2000
///TOOL 1
P00123=-1414.686,140.001,-695.627,179.9985,0.0001,89.1999
///TOOL 0
P00124=-1414.679,140.000,-145.000,179.9979,0.0002,89.2000
//INST
///DATE 2015/07/11 10:56
///ATTR SC,RW
///GROUP1 RB1
///LVARS 6,1,8,0,0,0,0,0
NOP
' PICK SLIP SHEET
' Store in cube 64 output
SPEED VJ=27.50 V=275.0
DIN LB000 SOUT#(120)
CALL JOB:AUTOHOME IF LB000=0
' Slip sheet pick pounce position
MOVJ P120
'Turn on picking ss to plc
DOUT OT#(78) ON
' Wait for slip sheet OK
WHILE IN#(65)=OFF
RET IF IN#(41)=ON
RET IF IN#(85)=ON
ENDWHILE
' Set start position
' Set start position equal to
' end position
SET P121 P122
' Extract current Z value
GETE LD001 P121 (3)
' Add in offset amount
SET LD001 EXPRESS LD001 + 900000
' Store new Z value
SETE P121 (3) LD001
' Set incremental position
' Set position equal to zero
SUB P101 P101
' Store Z increment
SETE P101 (3) 75000
' Set depart position
' Set depart position equal to
' end position
SET P124 P122
GETE LD001 P124 (3)
' Store new Z value
SETE P124 (3) LD001
*RETRY
' Turn on vacuum
CALL JOB:VAC_OFF
' Turn on solenoid to limit vac
DOUT OT#(21) ON
' Slip sheet start position
MOVJ P121 PL=1
' Turn on vacuum
CALL JOB:VAC_ON
DOUT OT#(21) ON
' Check for fast search
IFTHEN IN#(2045)=ON
' Move to last found position
MOVL P123
ENDIF
' Search for slip sheet
MOVL P122 V=20.0 UNTIL IN#(3)=ON
SETE P101 (3) 0
' Move away
DOUT OT#(21) OFF
IMOV P101 V=75.0 PL=0
' Store last found position
GETS PX123 $PX000
' Convert last found position
CNVRT PX123 PX123 BF
GETE LD001 P123 (3)
SET LD001 EXPRESS LD001 + 100000
' Store new Z value
SETE P123 (3) LD001
SETE P101 (3) 100000
' Move away
IMOV P101 V=50.0 PL=0
' Check slip sheet present
IFTHEN IG#(1)=0
' Increment retry count
ADD LB005 1
' Retry 3 times
IFTHEN LB005<=3
JUMP *RETRY
ENDIF
CALL JOB:CHK4SS
ENDIF
'Turn off picking ss to plc
DOUT OT#(78) OFF
' Slip sheet pick depart
MOVL C00000 V=500.0
TIMER T=0.50
MOVL C00001 V=500.0
CALL JOB:CHK4SS IF IN#(3)=OFF
' Set part held
SET I119 11
' Set OK for fast search
PULSE OT#(2029)
MOVJ P120
END
