hi people,
i am using the product designed for rotating application, which is supposed to be controlled with the KUKA motor. Motor name is MG_40_80_45_S0. but the problem was when we connected the system along with the gear box it was rotating in weird motion i.e it rotates few deegrees then stops, again rotates few degrees and it stops, this motion continues.(when whole system is connected).
but when we use small hand drill machine to rotate the system, whole thing rotates pretty smooth and it is not even as powerful as Kuka motor we are using.
It made us realize may be we are missing some parameters setting, we have tried various different settings and failure was the result.
has anyone before worked or experienced such situation?
or if you guys have any idea what we might be missing ?
