Hi all, a quick question...
We have a abb robot with the s4c controller.
Were having issues with the weld data on a job.
We have a job where were welding 1.30mm steel bracket to a 1.30mm steel plate. The weld data was perfect and saved as wd2 running on 0.8mm wire.
We had a new job come in ( a one off) welding a 4mm steel backet to a 4mm plate. I foolishly changed the weld data (wd2) instead of creating a new weld data. Now i cannot get it perfect for the previous job. The weld is way too thin and blows through.
If i was to restore the robot using a back up, would it restore the weld data values. I.e weld voltage, wire speed and weld speed??? For that job? Im not too bothered about the 4mm job as ive have written down the correct valus for this and will create a new weld data for this.
Ive also opened up the back up copy using robo studio. I can see the weld data (wd2) but only shows (2,11,0) not the correct value as before. Obviously way too low.
Any help would be much appreciated!!!!!! Thanks in advance
