KAREL read a string from Teach Pendant
  • Bram Aarssen
  • November 17, 2021 at 10:09 AM
  • Bram Aarssen
    Hi there,
    I'm currently working on a project for a company which produces many different types of pallets. I'm currently in school but working on a project for a company for 20 weeks, so I'm definitely no expert:smiling_face:.
    For this project I was thinking of making an ARRAY OF PALLETS (PALLETS I've already defined). Each pallet has a name (for example QWERT1234) and 7 other parameters (integers)
    I know I need to use the READ statement for the 7 parameters, but how do I read a string (for the name) from the teaching pendant? I'm not having any results reading the KAREL manual, so I'm hoping this forum can help me with my problem.
    Kind regards,
    Bram Aarssen
    Edited once, last by Bram Aarssen (November 18, 2021 at 7:52 AM).
  • jmd2777
    34
    193
    • November 17, 2021 at 3:58 PM
    I've never used it before but look at section 11 "Dictionaries and Forms" in the Karel manual.
    I have seen examples there that display a form to the user and allow them to edit fields.
    Also, there is some information in Example B.12 DISPLAYING A LIST FROM A DICTIONARY FILE.
  • dha
    28
    397
    • November 18, 2021 at 10:55 AM
    Once I did something like this.
    I had one KAREL program which calculated positions for palatalizing.
    User set registers depending on product type: size of pallet, size of products, how many products were stacked and and if they overlapped in height and distance to next product.
    Each time you called KAREL program, it output next position.
  • SkyeFire
    1,052
    9,427
    • November 18, 2021 at 1:34 PM
    Quote from Bram Aarssen
    What does this mean? What string? Do you mean a string register? Or something the operator is typing on the pendant?
  • Bram Aarssen
    • November 18, 2021 at 1:36 PM
    I know what to do with the integer parameters. I just don't know how to read a string parameter.
    For example:
    Name = 'ABC123'
    Length = 1200 mm
    Width = 1200 mm
    Height = 160 mm
    The length, width, height is easy: READ(<param>). But how do I read a string input ('ABC123', 'CBA321') which the operator enters from the teach pendent.
    Need to add that I've spoken with some people within my company and we're not going to do it this way, but I'm still curious:winking_face:
  • SkyeFire
    1,052
    9,427
    • November 18, 2021 at 1:40 PM
    Enters how? Typing into an SR? Typing in response to a TP prompt? In what memory location does this string reside?
  • Bram Aarssen
    • November 18, 2021 at 1:48 PM
    Quote from SkyeFire
    Basicly I made a structure pallet which contains:
    Length:integer
    Width:integer
    Height:integer
    ... 3 other integers
    Within the program I wanted to give the customer the option to add a different type.
    Which would ask for a Name, Length, Width, Height... and save it within an array of my structure (pallet)
    So to select which pallet they wanted they would type in the name and it would search within the array for that name. If there would be a match the parameters would be set to the values within the array of that index.
    So if we've currently got:
    Length: 1000mm
    Width: 1000mm
    Height 140mm
    If we enter 'ABC123' which is the name at array[2]
    Length = array[2].Length
    Length = array[2].Width
    Length = array[2].Height
    That's what I wanted to design. But to enter a new type of pallet I needed to let the operator enter a name on the teaching pendent and save it to array[i].Name.
    Hope this clarifies my thinking process.
  • string
  • read
  • read string
