Spline single movement speed issue
  • Goodmorning.
    i started to use Spline blocks and i have some issue when i have to control the single speed or acceleration of the single "Spline movement".
    i don't understand why when i put in the single movement a different CP speed (EX: SPL PointPiattina1Off[3] WITH $VEL = SVEL_CP(0.50, , LCPDAT4)) it doesn't take it and keep using the default speed. i also tryed to delete the default speed of the Splineblock ( SPLINE WITH $VEL = SVEL_CP(2.0, , LCPDAT1) ) but nothing changed. I tryed to figured it out with the manual but i still don't get it. Any idea?
    this is an example of the code:
    SPLINE WITH $VEL = SVEL_CP(2.0, , LCPDAT1), $TOOL = STOOL2(FS1), $BASE = SBASE(FS1.BASE_NO), $IPO_MODE = SIPO_MODE(FS1.IPO_FRAME), $LOAD = SLOAD(2), $ACC = SACC_CP(General1), $APO = SAPO(General1), $ORI_TYPE = SORI_TYP(General1), $CIRC_TYPE = SCIRC_TYP(General1), $JERK = SJERK(General1), $COLLMON_TOL_PRO[1] = USE_CM_PRO_VALUES(0)
    SLIN PointPiattina1Off[1]
    SLIN PointPiattina1Off[2]
    SLIN PointPiattina1Off[4]
    SPL PointPiattina1Off[5]
    SLIN PointPiattina1Off[6]
    SPL PointPiattina1Off[7] WITH $VEL = SVEL_CP(0.50, , LCPDAT4)
    SLIN PointPiattina1Off[8]
    SPL PointPiattina1Off[9]
    SLIN PointPiattina1Off[10]
    SPL PointPiattina1Off[11]
    SPL PointPiattina1Off[12]
    SLIN PointPiattina1Off[13]
    SPL PointPiattina1Off[14]
    SPL PointPiattina1Off[15]
    SLIN PointPiattina1Off[16]
    SPL PointPiattina1Off[17]
    SPL PointPiattina1Off[18]
    SLIN PointPiattina1Off[19]
    SPL PointPiattina1Off[20]
    SPL PointPiattina1Off[1]
    ENDSPLINE C_SPL
  • Nevermind guys...sorry, i got it now. One more question since i'm here. To change the approximation of the single line is it correct to change the $APO_CDIS or there is something different i can use?
    ex:
    SPL PointPiattina1Off[3] WITH $VEL.CP = 0.05 , $APO.CDIS=50
  • I do not understand your question. Inside a spline block there is no blending. You define the geometry by your sequence of target positions and this sequence gets an interpolating spline.
    If you want to a free form curve model it with a sequence of SPLs inside the block. Thats what it is for.
    Fubini
  • i'm asking this because i saw that there is a variable in the default structure that come up when you create a splineblock called APO_DIST. What is it refered to?
    EX: DECL LDAT LCPDAT2={VEL 2.00000,ACC 100.000,APO_DIST 500.000
