Hello guys!
Im experiencing a weird connection issue with workvisual, and I believe it could be a stupid config, but i have not been able to identify what is happening.
So, I have a computer which is connected via ethernet cable to a router using fixed IP (172.31.1.130) and the controller is connected to the router via KLI interface (XF5 port to be exact).
When i have my laptop (Mac running windows in Parallels with the wifi setup to the same ip range as the controller), it will connect 100% of the time with the controller, never once have failed to find the controller.
In comparison, the computer which is wired to the router, it has failed for over a month finding the controller, to suddenly find it for another month, and now has just stopped fiding completely.
I have tried changing the IP address and have ensured to set the network as particular, and open ports on windows firewall (also tried to disable firewall), but I have not been able to connect to it since.
Ping works perfectly, and I can also communicate with the controller using KukaVarProxy, but workvisual wont work...
Any ideas of what i could try? I have set gateway address as router ip so i can set up network as private. Before this change it showed the same behaviour, not being able to connect.
