DX200 / CP1616 Drops IP Address?
  • paranoidandroid
  • November 9, 2021 at 5:33 PM
  • paranoidandroid
    26
    Hey Motoman RF,
    Is anyone dealt with the issue of the CP1616 dropping the static IP address if the controller is shut off? I can go and re-assign with PRONETA or TIA Portal after the fact and re-establish connection but this would prove problematic if we lose power at the plant and have to re-assign IPs to EVERY robot controller after.
    Suggestions? Haven't been able to find anything in the PROFINET documentation from Motoman just yet.
    Thanks,
    -PA
  • Robodoc
    56
    7
    1,057
    • November 13, 2021 at 3:02 PM
    If your card keeps loosing it's IP address, boot in maintenance mode and write the address to the card to make it permanent.
    Robodoc
  • paranoidandroid
    26
    • November 18, 2021 at 6:59 PM
    Can you elaborate? I've gone thru all the menus for the CP1616 card in maintenance, can't find an option to statically assign IP for the card. I can for the controller, but not the same issue.
  • paranoidandroid
    26
    • January 6, 2022 at 4:22 PM
    Following up. I understand what your feedback is now Robodoc. Just got finished working with Motoman technical support.
    For clarity, this is from their troubleshooting:
    Problem
    Some customers report that the IP address is lost at power cycle or some other conditions. When looking at the card in TIA Portal or other Siemens software the IP address will show as 0.0.0.0.
    Resolution
    Our suggestion to save the IP Address as follows:
    1.       Start the YRC1000 or DX200 in “Maintenance Mode”
    2.       Once fully booted set the IP address again from the Siemens software.
    3.       This will put the CP1616 board into a mode which it can save the setting properly.
    4.       No settings within the robot controller itself need to be set or changed.
    5.       Cycle power to the robot controller.
    One additional countermeasure - if you have the TIA-project for the CP1616 you can execute the “factory reset” first and load the TIA-project again.
    Happy programming...
    -PA
