I want to know about Timer Flags under variable menu (YRC1000 controller), I couldn't find about it in any manual.
Do anyone know where it can use and give an example for it?
In the inform list there are commands to start, stop and reset a timer. You can start the timer at the top of a program and stop it at the end to see how long the program is in time. This way you can do some edits and see if your edits increased or decreased cycle time, of you can see if someone on an "off" shift changed your program. The display under variable is just a display of the current time.
Thank you for answer, my means wasn't Time (TM) under variable menu, my means was Timer Flag (TF) under variable menu.
As I said, the Timer Flag page under variable is to show the amount of time in a timer you have programmed with the timer start and timer stop commands.
