Karel Instruction for Recovery
  • Hello
    I have an application that runs a Karel subroutine from a third party application
    the problem is that this routine has a severity that aborts the entire Robot when an error happen inside
    i was able to write a karel instruction to avoid from Abort it, but when i resume it, it goes to the same line in the program that cause the error
    is there a way in Karel to put a:
    Jump next line
    Skip instruction
    End routine
    or something similar?
    Process routine:
    3: IF (DI[23:OFF:In Dry Cycle]),JMP LBL[90] ;
    4: ;
    5: !Point Soldering ;
    7: CALL NOABORT_EX ; // Instruction that avoid Abort
    8: CALL AS_LYRA('PSOL',AR[1]) ; // Generates an Abort error when wire is clogged)
    9: ;
    10: LBL[90] ;
    11: ;
    12: !End of Routine ;
    13: LBL[99] ;
    PROGRAM noabort_ex
    %NOLOCKGROUP
    BEGIN
    --SOLDER CLOGGED HANDLER
    CONDITION[801]:
    WHEN ERROR[97007] DO
    NOABORT
    ENDCONDITION
    ENABLE CONDITION[801]
    END noabort_ex
    the problem is that when I resume program it try to run program from the same line,
    1.- Karel instruction runs and avoid the abort
    2.- Fanuc calls Lyra instruction and this abort the program
    Robot is Paused now
    3.- I try to rerun the program, but i need to jump that line and continue with the normal execution of the routine
    i was looking for a way to skip line or end routine option
    I'll take a look into the GoTO end_PROG, can u put an example
