CRX-10ia DCS Payload Errors
  • Skynet24
  • November 5, 2021 at 6:45 PM
  • Skynet24
    Hey Guys,
    I'm hoping to get some assistance with the current issue we are facing with our Fanuc CRX-10ia/L Cobots. We are continuously running into an issue where J2 will get over 100% on the payload monitor DCS screen and our robot will lock up since the forces on it are too high and we are unable to move the robot at all unless we power down the controller and power it back up. Usually as we jog the cobot around we will first get a warning stating "SYST-348 Payload Monitor (Force) Warning" and eventually it leads to a "SYST-328 Not move in STOP state" error. The crazy thing is that we have nothing attached to the robot faceplate at all. We also verified that our payload is 0 and all the center of mass/inertia data is set to 0 as well.
    My assumption is that the robot should be performing the auto self check every opportunity it gets, and if it passes, it resets all the force/payload sensor values to 0. What I've seemed to notice is that it isn't resetting itself or performing the auto self check consistently (even when the robot isn't moving) and I'm not sure if that is the root cause or a cause because of elevated forces on the robot. I can verify this through the variables that show the auto self check timer and how quickly it is performed.
    We have two of these Cobots and both are doing the exact same thing, so it's highly unlikely that its a mechanical fault with the robot but a more likely that it's a DCS setting itself. As far as our DCS setup goes, all we have configured is our Safety IO that has things like ESTOP linked to it. We don't have any safety zones or CPC zones set up as we won't have a need for that since all our robot plans to do is have a camera as the end of arm tool to take pictures.
    Also to note, our Force limits are set to the default 150N with a margin of error of 60N.
    Has anyone else experienced this issue and figured out a solution? I feel like it has to be something within our DCS settings but can't seem to find it.
    Any input is greatly appreciated.
  • mR.PCX
    29
    • November 9, 2021 at 8:06 PM
    Can you send me your all of above Backup Please ?
  • dozer1971
    7
    • November 11, 2021 at 2:37 PM
    I would set the payload closer to what it actually is. In this case since you have no tool I would set the payload at 1 kg and see what happens. Since the default payload is set a 10 kg and the margin of error is 60 newtons you are outside of it and the robot will fault. The payload force warning it telling you that what you have entered in the payload does not match what robot is seeing. It doesn't necessarily mean that it is overloaded. Your stop state is happening because the payload is not correct.
  • kenton
    • May 3, 2022 at 11:50 PM
    My robot is doing the same thing. but I have set the payload to be correct
    it will run for a while then I have to reset the payload
  • dyno20
    • May 4, 2022 at 11:06 PM
    I had issues with payload. The latest firmware fixed my issues.
  • dozer1971
    7
    • May 5, 2022 at 4:45 PM
    Can you tell me what firmware you are using? Did you update the Tablet Application software as well?
    Thanks.
  • Hubert_Bonisseur
    • December 11, 2024 at 11:56 AM
    Hello, i have the same issue with a welding cobot (CRX 10iAL). The welding cable increase the payload and i have de SYST 321 error.
    It's the main issue i have with this robot.
  • gpunkt
    119
    456
    • December 12, 2024 at 1:56 PM
    Quote from Hubert_Bonisseur
    Update the system software, it will allow for more external forces nowadays.
    Also, make sure that the cables/hoses are lifted by balance blocks to minimize their impact on the robot.
    Then there are payload compensation instructions you could use (see the Tablet TP manual for further reference).
    And, of course, make sure that the payload setting is correct!
  • gpunkt
    119
    456
    • January 22, 2025 at 8:52 AM
    Quote from OB1
    How and where? Thanks
    How and where what?
  • Payload
  • CRX-10iA
  • CRX-10iAl
  • Cobot
