How to setup an automatic tool height adjustment system ?
  • Wall-E
  • November 5, 2021 at 3:39 PM
  • Wall-E
    245
    I'd like to set up an automatic tool height adjustment system, as in this video :
    External Content youtu.be
    That would be on a KRC4 system ; Robot : KR210 r3100.
    I plan to do mostly milling and my spindle has an automatic tool changer too, so even though my tools will be preset, I'd like to have a systematic re-adjustment performed at each tool change.
    Advice, someone ?
  • Go to Best Answer
  • panic mode
    1,280
    13,086
    • November 5, 2021 at 4:21 PM
    there are ready products for this or if DIY it is a simple interrupt based search. this was covered zillion times already
  • Dzonzi
    10
    222
    • November 5, 2021 at 11:56 PM
    Buy this https://vmt-vision-technology.com/765/en/automotive/vmt-toolbox-3d
  • Wall-E
    245
    • November 7, 2021 at 3:11 PM
    Thanks for the link, but I'm not looking for a fancy 3d optic scanning tool.
    Just a basic tool tip contact.
  • Wall-E
    245
    • November 7, 2021 at 3:17 PM
    Hi Panic,
    I must be a very bad keyword search guy, or the search engine sucks, I don't know...
    Would you mind pointing me towards one of those zillion posts ?
  • panic mode
    1,280
    13,086
    • November 7, 2021 at 4:15 PM
    if you click on top link that takes you do manuals section, top post in there is an interrupt example
    Interrupt Example
  • panic mode
    1,280
    13,086
    • November 7, 2021 at 5:29 PM
    or something like this:
    ISR_Search_And_Stop.SRC
    DEF ISR_Search_And_Stop( )
    BAS(#INITMOV,0)  ; INI
    BAS(#TOOL, 1)    ; set tool 1
    BAS(#BASE, 0)    ; set base as WORLD
    ; move to initial position
    BAS(#VEL_PTP,50)  ; 50%
    BAS(#ACC_PTP,100) ; 100%
    PTP $AXIS_ACT   ; do a BCO (exteral axes too!)
    PTP {A1 0, A2 -90, A3 90, A4 0, A5 90, A6 0}
    ; first - setup search
    INTERRUPT DECL 10 WHEN MySensor==TRUE DO Found_It()
    FoundPos = {X 0} ; clear search result
    WAIT FOR MySensor==FALSE ; make sure sensor is off
    ; then - perform search
    INTERRUPT ON 10
    Search()
    INTERRUPT OFF 10
    ; then - display results
    WAIT SEC 0 ; stop advance run pointer
    IF VarState("FoundPos.Z")==#INITIALIZED THEN
      MsgNotify("Found at Z= %1 mm",,FoundPos.Z)
    ELSE
      MsgNotify("Not Found")
    ENDIF
    END
    DEF Search()
        ; for search use slow LIN motion
      BAS(#VEL_CP,0.1) ; 0.1 m/s
      BAS(#ACC_CP,100) ; 100%
      LIN_REL {Z -200} ; move down - max 200mm
    END
    DEF Found_It()
      BRAKE  ; stop search motion
      FoundPos=$POS_INT ; save everything, not jut Z
      RESUME ; abort SEARCH() and resume main program
    END
    ISR_Search_And_Stop.DAT
    DEFDAT  ISR_Search_And_Stop PUBLIC
    SIGNAL MySensor $IN[666] ; adapt as needed
    DECL POS FoundPos={X 0}
    ENDDAT
  • Wall-E
    245
    • November 9, 2021 at 9:34 AM
    Great ! I'm looking around for hardware and found this :
    https://www.amazon.fr/Capteur-automa…005&sr=8-2&th=1
    It looks like there is two versions :
    -"Normally open"
    -"Normally closed"
    I guess that it will just either continuously be at "0" state or at "1" state until it is touched by the tool, and then it switches.
    But what's the advantage of one over the other ?
    Also, I see it has some kind of blower to clean the tool. I suppose it can be activated through the robot controller with an output and a solenoid valve...
    Edited once, last by Wall-E (November 9, 2021 at 11:14 AM).
  • Mentat
    61
    5
    243
    • November 10, 2021 at 1:26 PM
    • Best Answer
    Quote from Wall-E
    Safety - when it inevitably breaks and always returns 0. The one that normally is at 0 won't seem any different from when it wasn't broken.
    SkyeFire
    1,052
    9,429
    • November 11, 2021 at 12:26 AM
    Quote from Wall-E
    Quote from Mentat
    As Mentat said. Imagine what would happen if someone unplugged the sensor, or just tripped over the cable and damaged it, or it just wore out. You want to pick your components such that, if a typical failure happens, you can see some indication of the issue before the robot hits something.
  • Wall-E
    245
    • November 15, 2021 at 4:53 PM
    • #11
    OK, so the "Always closed" is to one to go for.
    Thanks fellows.
