sending xml files using Server/Client TCP socket.
  • Jasser
  • November 4, 2021 at 11:44 AM
  • Jasser
    Hello everyone,
    In my works I want to send XML files throw a TCP/IP connection (ETHERNET cable) from my pc as a severe to my KRC 4 as a client (robot KUKA KR-16-2).
    I'm working on a python program that suppose to send XML file to the KUKA controller robot using Server/Client TCP socket.
    But the problem is I have to send my XML file always like a bytes (image1). So can the kuka controller understand that the information received is an XML file and used in a KRL code ?
    In my XML file I want to send the variation of an analogic signal (angular variation of a joystick) so the value inside the XML file need to be updated every time the angulation value of the joystick change, so it's possible to do that using Server/Client TCP socket?
    Thanks for help.
    Images
      • 29.68 kB
      • 617 × 529
      • 62
  • panic mode
    1,296
    13,136
    • November 4, 2021 at 1:40 PM
    check documentation for EthernetKRL
  • johncena690
    5
    • March 30, 2023 at 4:27 PM
    any chance this issue was resolved. I tried a similar method and it says "Machine Actively refused the connection".
    Do you have any idea how to rectify this error?
  • panic mode
    1,296
    13,136
    • March 30, 2023 at 5:17 PM
    the XML structure in your TCP message that you are sending must match EKI configuration...
    if the format does not match, received messages will not be decoded.
  • johncena690
    5
    • March 30, 2023 at 6:38 PM
    <cloud>
    <para>
    <weld>
    <ps1pow>10</ps1pow>
    <ps1al>5</ps1al>
    <ps1dc>6.6</ps1dc>
    <ps1bb>-5.8</ps1bb>
    <ps2pow>1.1</ps2pow>
    <ps2al>5.5</ps2al>
    <ps2dc>6.6</ps2dc>
    <ps2bb>-5.8</ps2bb>
    <weldvel>0.5</weldvel>
    </weld>
    </para>
    </cloud>
    this is the .xml file I have. Can you let me know if this is right?
  • panic mode
    1,296
    13,136
    • March 30, 2023 at 7:54 PM
    how would i know? you did not share the EKI configuration. both message and configuration need to match.
    when send config looks like this:
    <SEND>
      <XML>
        <ELEMENT Tag="FromKRC/TickCount"/>              <!-- INT -->
        <ELEMENT Tag="FromKRC/Ready"/>                  <!-- bool -->
        <ELEMENT Tag="FromKRC/Faulted"/>                <!-- bool -->
        <ELEMENT Tag="FromKRC/DrivesOn"/>               <!-- bool -->
        <ELEMENT Tag="FromKRC/AtHome"/>                 <!-- bool -->
     </XML>
    </SEND>
    message sent by robot would look like this (shown with line breaks):
    Quote
    <FromKRC>
    <TickCount>666</TickCount>
    <Ready>1</Ready>
    <Faulted>0</Faulted>
    <DrivesOn>1</DrivesOn>
    <AtHome>1</AtHome>
    </FromKRC>
    the same thing is for reverse (robot receiving).
    the XML configuration tells to EKI how to format send message (encode) and parse received message (decode).
  • johncena690
    5
    • March 30, 2023 at 8:10 PM
    This code snippet you shared is when the external pc is receiving data from kuka krl right?
  • panic mode
    1,296
    13,136
    • March 30, 2023 at 8:17 PM
    yes... as stated in the previous post.
  • johncena690
    5
    • March 30, 2023 at 8:26 PM
    this is the config file snippet
    <RECEIVE>
        <XML>
            <ELEMENT Type="REAL" Tag="cloud/para/weld/ps1pow"/>
            <ELEMENT Type="REAL" Tag="cloud/para/weld/ps1al"/>
            <ELEMENT Type="REAL" Tag="cloud/para/weld/ps1dc"/>
            <ELEMENT Type="REAL" Tag="cloud/para/weld/ps1bb"/>
            <ELEMENT Type="REAL" Tag="cloud/para/weld/ps2pow"/>
            <ELEMENT Type="REAL" Tag="cloud/para/weld/ps2a1"/>
            <ELEMENT Type="REAL" Tag="cloud/para/weld/ps2dc"/>
            <ELEMENT Type="REAL" Tag="cloud/para/weld/ps2bb"/>
            <ELEMENT Type="REAL" Tag="cloud/para/weld/weldvel"/>
        </XML>
    </RECEIVE>
    this is the xml file snippet
    <cloud>
      <para>
        <weld>
          <ps1pow>10</ps1pow>
          <ps1al>5</ps1al>
          <ps1dc>6.6</ps1dc>
          <ps1bb>-5.8</ps1bb>
          <ps2al>5.5</ps2al>
          <ps2dc>6.6</ps2dc>
          <ps2bb>-5.8</ps2bb>
        </weld>
      </para>
    </cloud>
    I am trying to send the data from my PC to the KUKA Controller
  • panic mode
    1,296
    13,136
    • March 30, 2023 at 8:34 PM
    before message exchange can take place, connection need to be established. this also means one node is to work as a client, the other as server, server must be started first then client need to connect to server etc.
  • johncena690
    5
    • March 30, 2023 at 8:39 PM
    • #11
    So If I start the server first and then send this xml straight forward using python based TCP/IP it should work right.
    But still the same error keeps coming (Target Machine Refusing the connection). Can you let me know how to send the xml file directly through python and are any more modifications required in the xml or config file?
    I used EthernetKRL_Server.exe file to send data using their own interface and then there wasnt any issue( by directly copy-pasting the xml file).
    But while using python the connection issue is popping up.
  • SkyeFire
    1,060
    9,456
    • March 30, 2023 at 8:56 PM
    • #12
    Quote from johncena690
    Same computer/cables/network switch/etc?
    Then the problem probably has to be with your Python program. But there are about 5000 different methods to open TCP/IP connections in Python. And since whatever Python library you're using is throwing that error, you need to look into the documentation for that Python library.
  • panic mode
    1,296
    13,136
    • #13
    if you want your computer and robot controller to talk to each other, they need to be on a same network and have compatible network settings. and make sure you are connecting to a correct port.
  • MOM
    176
    7
    1,424
    • March 31, 2023 at 4:53 PM
    • #14
    I think here a different network is used (SMEM)
    did you run your python on the krc (SEM) or from a different computer (LAN)?
    In this case you are using a network which cannot be reached by your program unless your kli settings are correct
  • Python
  • xml file
  • KUKA kr16
