Learning INTERRUPTS and facing a problem
  • mihnea0071
  • November 3, 2021 at 11:44 AM
  • mihnea0071
    53
    Hello guys,
    I am in the process of reading/practicing with Interrupts. Lucky we have a KRC2 controller with a KR 70 R2100 robot with KSS 5.6 to practice with.
    I tried to use INTERRUPTS to trigger different subprograms, everything works fine with the ones that has only LOGIC commands without movement commands like PTP.
    When I trigger the Interrupt which opens the subprogram with different movements I got some Bas problems, can somebody explain to me how to correct this?
    I use the following code:
    MAIN PROGRAM ()
    INIT
    DECL INTERRUPT 10 WHEN $OUT[192]==TRUE DO TOOL ()
    INTERRUPT ON 10
    PTP_HOME
    $ADVANCE = 0
    OUT 192 STATE TRUE
    PTP_HOME
    END
    TOOL ()
    INIT
    PTP_HOME
    PTP_HOME
    END
    Thnak you in $Advance!
    Images
      • 193.1 kB
      • 1,600 × 1,200
      • 7
  • Fubini
    284
    1,906
    • November 3, 2021 at 12:37 PM
    • Best Answer
    Inside Interrupts no Inlineforms are allowed. Only expert plain krl motion commands.
    Fubini
  • the leg
    643
    • November 3, 2021 at 12:40 PM
    you cannot use the interrupt program for motions like that you can use global positions rel moves and such nothing with the inline form
  • mihnea0071
    53
    • November 3, 2021 at 12:49 PM
    Thank you for the clarifications guys!
