Hi all,
I've been now two days with the same issue... I'm using an HMI to run a MAIN program (Prog Select configured correctly). When working in AUTO, no active alarms, and ABORT done, UI[6] pop-up ON but the system is not running as the SYST-011 or SYST-034 alarm pops out stating: Failed to run task.
The thing is that when I turn on the manual mode, I'm able to do FWD and start running the program. After this, if I cange back to AUTO and try to run the program.... It works! Except if an ABORT is done between both working modes.
Does anyone have a clue about this? I will really appreciate it
Thankyou!
