non-integer num im KAREL
  • Hello,
    How can i use a non-integer number in a register? Im karel prg R[6] value always 0.:unamused_face:
    TP program:
    R[7]=1.2
    R[8]=1.4
    R[6]=[R7]+[R8]
    Karel:
    VAR
    reg : ARRAY[3] OF INTEGER
    status : INTEGER
    real_flag: BOOLEAN
    real_value:REAL
    BEGIN
    GET_REG(6, real_flag, reg[6], real_value, status)
    GET_REG(7, real_flag, reg[7], real_value, status)
    GET_REG(8, real_flag, reg[8], real_value, status)
    SET_INT_REG(6,reg[7]+reg[8],STATUS)
    Can somebody help me?
  • How does it "not work"? Details matter. Show your code, inputs, outputs, and error messages (if any)
    This is just a test program, it can be generated in p code, I can run the .pc file, but the register always remains 0. Also with the "SET_REAL_REG" command. If I use an integer in the value of R [7], R [8], that's fine. If R [7], R [8] is not an integer, R [6] is 0. No error message.
    code:
    PROGRAM reg_test
    %COMMENT = 'reg test'
    %ALPHABETIZE
    %NOBUSYLAMP
    %NOABORT = ERROR + COMMAND + TPENABLE
    %NOPAUSE = ERROR
    %NOPAUSESHFT
    VAR
    reg : ARRAY[10] OF INTEGER
    status : INTEGER
    real_flag: BOOLEAN
    real_value:REAL
    BEGIN
    SET_REAL_REG(6,reg[7]+reg[8],STATUS)
    END reg_test
  • You may be misunderstanding how GET_REG works.
    Its behavior depends on the contents of the register.
    Example 1: let R[6] = 2
    Result:
    real_flag = false
    reg[6] = 2
    real_value = ? (possibly uninitialized)
    Example 2: let R[6] = 2.34
    Result:
    real_flag = true
    reg[6] = ? (possibly uninitialized)
    real_value = 2.64
  • You're using GET_REG wrong. You're pushing the Integer result returned by GET_REG into REAL_VALUE.
    You need to create an Integer variable, as well, and:
    GET_REG (Register_Number, REAL_FLAG, INTEGER_VALUE, REAL_VALUE, STATUS)
