We are trying to upgrade un KRC2 cabinet from Win95 to WinXP (no Ed05). We seem to have the proper hardware
* 320 RAM RAM
* Soyo Motherboard 733MHz
* new DSE-IBS-C33 attached to the MFC2 which came with the win95 version in the KRC2 cabinet
* RDW2 version 4.0 and 4.1
We have installed the following software version:
- WinXP 2.00
- Kuka softwareV 5.2.12 Built 69 HF3
WInXP starts up without error, yet when the Cross3 starts it gets stuck in 10% and it appears the following warning message (the starting up stops there),
Uploader dll: version 2.01
device driver interface dll (lptw32.dll) version 3.10
driver LPVXWRT.vxd/sys) version 5.00
No shared Memory Network driver yet installed
Error
Invalid version of the device driver (LPVXWRT.vxd/sys)
Actual version= 5.00
needed version = 4.01
Maybe we do not install the soft properly (drivers for the DSE) or maybe we are not installing the right software version.
When we install the KUKA Soft 5.xx we do not install the SMSetup like we do with the 4.xx versions under Win95. I do not think that this is necessary with the 5.2.12 versions because it does it automatically, doesn't it?.
It is clear to us that there is no connection between the DSE and the RDW2.
Under windows95 we have install the SMSETUP in order to install the drivers for the DSE so there is communication with the RDW. That happens in win95 but we do not see any similar application with the Kuka version for XP (versions 5.xxX) . There is no SMSETUP.
Any suggestion?
Regards
