I am trying to learn socket programming with Karel and I am following the example program given in the reference manual. I am simulating this on Roboguide with R-30iB controller.
This is the program code:
PROGRAM sock_test
%NOLOCKGROUP
%NOPAUSE=ERROR+COMMAND+TPENABLE
%ENVIRONMENT uif
%ENVIRONMENT sysdef
%ENVIRONMENT memo
%ENVIRONMENT kclop
%ENVIRONMENT bynam
%ENVIRONMENT fdev
%ENVIRONMENT flbt
%INCLUDE klevccdf
%INCLUDE klevkeys
%INCLUDE klevkmsk
VAR
j1 : JOINTPOS
j1_deg : ARRAY[9] OF REAL
status: INTEGER
status1: INTEGER
prog_index: INTEGER
BEGIN
--j1_deg[1] = 0.0
--j1_deg[2] = 0.0
--j1_deg[3] = 0.0
--j1_deg[4] = 0.0
--j1_deg[5] = 0.0
--j1_deg[6] = 0.0
--j1_deg[7] = 0.0
--j1_deg[8] = 0.0
--j1_deg[9] = 0.0
j1 = CURJPOS(0,0)
CNV_JPOS_REL(j1, j1_deg, status)
j1_deg[2] = 0
CNV_REL_JPOS(j1_deg, j1, status)
IF status = 0 THEN
SET_JPOS_REG(1, j1, status1)
CALL_PROG('TEST1', prog_index)
ENDIF
END sock_test
When I build this, I get the following error:
41 SET_JPOS_REG(1, j1, status1)
^ ERROR
Id must be defined before this use. Id: SET_JPOS_REG
===============Translation not successful===============
Build Failed: Error translating program: Code: 0xFFFFFFFF:
But if I comment out the %ENVIRONMENT lines, it builds correctly. Can somebody tell me what am I missing?
Thank you.
