Why is my VR[1].Found_Pos[2] Blank?
  • Devon
  • October 20, 2021 at 7:47 PM
  • Devon
    18
    Hi everyone,
    I've got an issue where my vision process is picking up the 4 items it should be, but my VR[1].Found_Pos[2] is blank (and so it Found_Pos[3] and Found_Pos[4]). Should it not be showing me the all 4 items found? I need a way to get the position of all 4 so I can send them to the PLC. Vision process attached.
  • jmd2777
    34
    193
    • October 20, 2021 at 9:06 PM
    Here is my understanding:
    A VR stores the data for a single workpiece at a time.
    The value of Found Pos 1 stores the result for Camera View 1, Found Pos 2 stores the result for Camera View 2, etc. You are using 1 Camera View, so the other Found Pos fields should be blank.
    You would need to call GET_OFFSET again. Then you would see the location of 2nd part that was found in Found Pos 1.
    From the manual:
    "GET_OFFSET stores the vision offset for a workpiece in a vision register. When the vision process
    finds more than one workpiece, GET_OFFSET should be called repeatedly."
    A typical workflow is to use GET_NFOUND to find out how many workpieces were found. Then create a FOR loop and call GET_OFFSET for each workpiece.
  • Devon
    18
    • October 21, 2021 at 1:53 PM
    Ahh, that makes sense, thank you!
    Now here's where I think it gets a little more complicated. This is a line tracking setup, so VR[1] gets populated from the queue when called. I don't believe I can pull the offset data I want at that point, correct? So I could need to pull it during the original image capture and get the offsets then? Then also pull 4 VRs when I do my GETQ?
  • jmd2777
    34
    193
    • October 22, 2021 at 3:27 PM
    Sorry, I don't know about line tracking.
Similar Threads
  • MONITOR INSTRUCTION PROBLEM
    • Alex Sleep
    • October 12, 2021 at 2:30 PM
    • Fanuc Robot Forum
  • Karel uninitialized data.
    • neighbour1
    • October 8, 2021 at 5:51 PM
    • Fanuc Robot Forum
  • IRVISION not picking up part in correct rotation every time.
    • djshaun5
    • October 11, 2020 at 6:24 AM
    • Fanuc Robot Forum
  • Main CPU LEDS and ALARMS
    • AleynaKiratLi
    • March 22, 2021 at 12:57 PM
    • Fanuc Robot Forum
  • Fanuc Robot Serial Number issue
    • jariuscs
    • March 11, 2021 at 4:00 PM
    • Fanuc Robot Forum
  • Contact before search
    • MurryM
    • September 30, 2020 at 5:06 PM
    • Fanuc Robot Forum
  • Use of ";" in fanuc R-30i program
    • eldepon
    • February 5, 2019 at 2:01 AM
    • Fanuc Robot Forum
  • Found_Pos[2]
Users Viewing This Thread
  • 1 Member
  • Christian Aldrin Sanchez
