Safe Operation Mode
  • Rainman
  • October 20, 2021 at 8:51 AM
  • Rainman
    108
    Dear Friends
    Here I have a KRC2 edition 2005 ( ,I have made a Dummy bride plug connector( X40 ) one the robot manipulator and also for (X211C) Under the robot controller
    by the way I have Deactivated SafeOperation functionality by Set the parameter SafeRobot disabled to TRUE,
    Now I can work with robot just in T1 !!!
    I can't work with other modes like as #T2,#AUT,#EXT
    when I switch to these modes I will see this error Message :Emergency Stop By Safety Controller !!!
    Does any body knows how I can Solve this problem ?
    Please Help .If U have any experience
    Images
      • 201.28 kB
      • 1,920 × 1,080
      • 60
      • 197.16 kB
      • 1,920 × 1,080
      • 36
  • Rainman
    108
    • October 20, 2021 at 9:23 PM
    Hi
    I have read an old tread on this forum that written that "We can do the jumping of X40 - it doesn't need a cable to 21.1 - and it should work fine. "
    It means that if we jumped X40 we to remove the second data cable between X41 and X21.1 ?
    Is it true ?
  • hermann
    412
    2,624
    • October 21, 2021 at 5:56 AM
    'Failure safety output' means that your jumpers on X40 are wrong.
  • Rainman
    108
    • October 21, 2021 at 7:41 AM
    My Special Thanks to Hermann
    According his note I have checked the Wring ,It was ok ,
    What was the problem, It was, crazy amazing point ,the connector was not good tighten to it's please because some stupid small screw on the connector surface plate :winking_face_with_tongue:
  • Rainman
    108
    • November 12, 2021 at 7:44 PM
    Hello again
    Where I can take the local emergency stop from X240 ,because when I take a look the robot drawing I didn't see any thing regarding this issue ?
  • panic mode
    1,296
    13,136
    • November 12, 2021 at 8:14 PM
    post the page from the drawing so everyone can chime in
  • Rainman
    108
    • November 12, 2021 at 8:30 PM
    Oh. I had a mistake , the safety peripheral interface is X211C , here I couldn't see robot local emergency pin out .
    Images
      • 1.83 MB
      • 1,920 × 1,080
      • 70
  • panic mode
    1,296
    13,136
    • November 12, 2021 at 8:38 PM
    Yes X211c if on Deimler controllers.
  • Rainman
    108
    • November 12, 2021 at 8:52 PM
    Yes, Panic Mode
    As you have mentioned they are connector pin out for External emergency and Operator safety from outside to the robot controller ,
    But in need Local emergency Stop pin out (Emergency Stop from robot controller to the outside)
    in attachment you can understood what I need , but this is for Standard robot (X11) ,
    Images
      • 152.01 kB
      • 980 × 766
      • 45
  • panic mode
    1,296
    13,136
    • November 12, 2021 at 10:06 PM
    If your controller does not have X11 don't look at X11 documentation. Get documentation for your controller version. Did you check READ FIRST and Xpert portal? You should find there documents for your system.
  • Rainman
    108
    • November 13, 2021 at 6:32 AM
    • #11
    I have checked the documentation of Expert portal ,I found nothing ,
    I have to think to manipulate this issue ????
    sjx
    28
    101
    • November 13, 2021 at 11:41 AM
    • #12
    X211C Daimler:
    Local E-stop channel A: 14 - 13
    Local E-stop channel B: 12 - 11
  • Rainman
    108
    • November 14, 2021 at 1:26 PM
    • #13
    Something is wrong here because in my electrical schematic that I have , Pinout 11-12 , 13-14
    Is used for transferring voltage between power module and ET200s Interface module that is installed in the robot controller !!!
    So these Pins in not assigned for robot local emergency stop .
    for better understanding take a look to the attachments.
    Files
    1.pdf 496.87 kB – 59 Downloads 2.pdf 145.28 kB – 45 Downloads
  • panic mode
    1,296
    13,136
    • November 14, 2021 at 4:02 PM
    • #14
    What makes you think that?
    Did you read the X211C relevant documentation? Did you even connect to Xpert as suggested?
    This document is one of the first listed. Page 14 leaves no doubt.
    I bet your ET200 unit contains output modules. so when E-Stop is ok, outputs are operational (powered up). Btw, the schematic you posted is for specific application. It also shows that in PLANT_MODE those would need to be bridged (and therefore independent of E-Stop).
  • Rainman
    108
    • November 16, 2021 at 6:55 AM
    • #15
    Thank you Panic Mode and SJX
    I have got the key ,My problem solved !!
Similar Threads
  • ABB IRC5 with Flex pendant remote start
    • fulmermike
    • September 1, 2021 at 11:07 PM
    • ABB Robot Forum
  • Security mode change when switching operation mode
    • MR21
    • November 9, 2020 at 2:43 PM
    • Yaskawa Motoman Robot Forum
  • USED KRC2 ed05- Cannot create New program or jog the robot at all
    • RoboIvan
    • January 16, 2021 at 9:50 PM
    • KUKA Robot Forum
  • Kuka safe robot
    • adaskox97
    • May 7, 2020 at 7:40 AM
    • KUKA Robot Forum
  • How to turn off safety output KUKA
    • Alex_Moser564
    • January 31, 2018 at 4:43 PM
    • KUKA Robot Forum
  • Access to expert mode
    • Rainman
    • May 30, 2019 at 10:19 PM
    • KUKA Robot Forum
  • KSS00364 - KSS01362 - KRC4 - KSS 8.2.25
    • Bad_block
    • May 29, 2019 at 6:51 PM
    • KUKA Robot Forum
  • KUKA Safe without SIB
    • MrNico
    • April 5, 2019 at 7:16 PM
    • KUKA Robot Forum
  • Protected workspaces in Safe Operation
    • fabi
    • February 13, 2019 at 1:48 PM
    • KUKA Robot Forum
