DX 100...
How can i look at other jobs when robot is running?
DX 100...
You can select and see jobs only in playback not running, in the running you can see only job that are running.
If you are using PSTART instruction (parallel start jobs), you can use PAGE key for see jobs that are running.
As the job is running you select job~select job (top left). You will then see the list of jobs. Now click job (again top left) and then the tab job edit should be available. When you select edit you can view by selecting other jobs as your master or other job is being ran. Changes to jobs aren't permanent in this mode though. You can make the changes but they are removed. there may be a parameter to do so but I dont know it.
