Stuck at Boot up
  • EPeters1
  • October 12, 2021 at 7:47 PM
  • EPeters1
    8
    111
    Putting together an RJ3iB controller from some used parts, expected certain problems but this has got me clueless.
    Had everything working properly for about a minute then got errors of blown fuses and FSSB error and LVAL error and i think a few others i was more familiar with. Powered down and checked fuses, mistakenly grabbed 1.5 A instead of 7.5 A fuses, dont know how I managed that but here we are. Pulled blown fuses and replaced them with the proper specification. Now when i turn it on it loads the files and gets to the "Starting System Software. please wait" part of the process and just stalls out.
    Tried an INIT start, gets stuck at the same spot.
    Tried to load img files, got stuck at SRAM 00
    Swapped TP cable for one I know works. No change.
    Swapped main board. No change.
    7 segment LED sometimes has 0 or 1
    I don't understand what is going on, I cant even boot up far enough to get an error code which is bonkers because it was functional for a brief minute this morning so unless a component spontaneously died then everything is confirmed functional.
    Edited once, last by EPeters1 (October 12, 2021 at 8:00 PM).
  • pdl
    268
    1,522
    • October 15, 2021 at 5:27 PM
    You could try reseating the ram board, but please know that this will absolutely clear any memory on it.
    Kind of a long shot, but it doesn't sound like you have any valid memory at this point because you already tried to restore an image.
  • EPeters1
    8
    111
    • October 18, 2021 at 12:42 PM
    had to swap out pulse amplifier which doesnt make any sense but it worked
Similar Threads
  • Background programs
    • SkyeFire
    • October 22, 2020 at 12:36 AM
    • Fanuc Robot Forum
  • Hang on Start Up KSS download System Files
    • RobotRobert
    • October 2, 2021 at 9:57 PM
    • KUKA Robot Forum
  • Joystick error
    • Alex De Jesus
    • September 1, 2021 at 4:53 PM
    • ABB Robot Forum
  • Linking a DO to a BG logic run state
    • SkyeFire
    • May 20, 2021 at 7:54 PM
    • Fanuc Robot Forum
  • i have a arcmate 100 fanuc robot that was stuck in boot menu i did a cold start but now the programs are gone is there a way to retrieve them no disc that i am aware of thanks for any help
    • ktmark
    • April 27, 2021 at 4:13 PM
    • Fanuc Robot Forum
  • Fanuc RJ-2 Start Up Issue
    • Brandon Garner
    • June 10, 2020 at 6:54 PM
    • Fanuc Robot Forum
  • KR5 sixx KRC2sr stuck on boot after HMI started
    • jpherbute
    • February 7, 2018 at 6:22 PM
    • KUKA Robot Forum
  • KRC4- Boot Failed for module KCP3Driver
    • saadkhulsai
    • December 6, 2018 at 1:02 PM
    • KUKA Robot Forum
