MOTN-049 Error Fanuc
  • Hey guys,
    I have a problem with Fanuc robot. I got MOTN-049 error. I did mastering, calibration. I check every forum and documentation. It is still not working. I can move with robot, but if I want to go FWD in job, I get this error again and again.
    Calibration and DCS is fine.
    Thank you for your answers,
    Dufino
  • The error means that the robot is not calibrated.
    What kind of Mastering you used.
    And afterwards you did a calibration?, just checking.
  • I set robot to zero position and did zero position mastering.
    Then I did calibration. Positions of axes were on zero.
    Then I was ask for DCS, I entered DCS, after asked pending I turn off/on robot controller.
    I can move with robot, but if I tried start job, error shows up again.
    Mr. Munoz unfortunately I can be with robot the following Monday. Then I can send you images.
    Thank you guys.
