MONITOR INSTRUCTION PROBLEM
  • Hi everybody. I have a problem with adding the MONITOR instruction. Syntax error:
    " INTP-274 (JOB_DROP_1, 1) CH program error
    " INTP-202 (JOB_DROP_1, 1) Syntax error " STOP.L
    HELP Please.
    Below are the program codes:
    1. The processing program (JOB_DROP_1) in which I need to control the input
    2. Monitoring program (C_MONITOR)
    3. event response program (FAULT1)
    /PROG JOB_DROP_1
    DEFAULT_GROUP = 1,*,*,*,*;
    CONTROL_CODE = 00000000 00000000;
    LOCAL_REGISTERS = 0,0,0;
    /APPL
    AUTO_SINGULARITY_HEADER;
    ENABLE_SINGULARITY_AVOIDANCE : TRUE;
    /MN
    1: MONITOR C_MONITOR ;
    2:J P[1] 100% FINE ;
    3: ;
    4:J P[2] 100% FINE ;
    5: ;
    6: MONITOR END C_MONITOR ;
    /POS
    /PROG C_MONITOR Cond
    DEFAULT_GROUP = *,*,*,*,*;
    /MN
    1: ;
    2: WHEN DI[2]=ON,CALL FAULT1 ;
    3: ;
    /POS
    /END
    /PROG FAULT1
    /APPL
    /MN
    1: DO[5]=ON ;
    /POS
    /END
  • Thank you. But you can see that the type of this program is COND
    "/PROG C_MONITOR Cond
    And it looks like CH in list of programs.
  • This is driving nuts.
    when I run drop-job-1 step by step and I get to MONITOR C_MONITOR i get an error that is a motion group
    it's not , i have ++++++++ on the 3 programs, drop-job (i delete the points), the monitor and the fault
    The C-MONITOR program can no be wrong because the only way to run the WHEN command is when the program is defined as condition
    Somehow the DROP+JOB_! program is "wrong", I dont see where
    Retired but still helping
  • This may be way off but:
    It looks like C_MONITOR has a blank line 1 and you put the WHEN on line 2. Try deleting the blank line 1 so that the WHEN is on line 1.
    I spent a whole day and night on this battle with the robot. I have already tried different program names, different conditions, and many other actions. I transferred programs from a real robot to Roboguide and got exactly the same errors.
    And only after deleting ALL the empty lines in the CH program did it finally start working.!!!:uglyhammer2:
    Thank you!
  • Sorry to hijack your post but I think we have to get to the bottom of this command issue for the rest of the people
    Look at the pictures
    I tried many things and still getting the error. What's interesting is that if I start the program at the first point, the robot actually executes the 2 points and the MONITOR END command, which does not make sense to me because as far as I see it never executed
  • i'll check it again. But everything become good without empty lines.
