Random Part Variation?
  • Tony R.
  • October 7, 2021 at 3:48 AM
  • Tony R.
    38
    Hi all,
    I need to do a vision sort for a simple pick-place HandlingPRO. For the sake of simplicity, let‘s say there are two identical parts, one red cylindrical part one blue. The robot analyzes the part and places it into one of two boxes. Everything works.
    However, it seems that when using Roboguide I must create two separate parts. The pick-place simulation then begins to get complicated, since the vision sort I need gets a little complex.
    Is there any way to create one part with random (or simply an SR[ ] seeded) color variation? If not, how do I go about handling this, especially if I have 4 or 5 variations that need local and shared processes?
    Thanks in advance,
    ~Tony
  • Fabian Munoz
    133
    Articles
    1,517
    • October 7, 2021 at 3:39 PM
    Hi
    I have no idea of your setup. Is it direct lighting ? Do you have filters ? Do you have a colour camera ? is the part sitting on a belt and your lighting illuminating from the bottom , so you can only see silhouettes ?
    Retired but still helping
    hermann
    405
    2,597
    • October 8, 2021 at 8:30 AM
    If I understand correctly, he has no camera at all, he uses Roboguide and wants to create different colored parts dynamically.
  • Tony R.
    38
    • October 8, 2021 at 3:09 PM
    Quote from hermann
    Yes Sir, that is exactly what I’m looking to create.
  • EnergyAddict
    45
    133
    • October 8, 2021 at 3:42 PM
    I do not believe you can change the color of a part in Roboguide dynamically (Or, at least I haven't found a way).
    When Dealing with multiple parts, I sometimes set up simulation programs that "Pick" & "Drop" parts From/To fixtures with "No Part". Allowing me to make certain parts 'visible' or 'hidden'. Unfortunately a good looking simulation video can be a bit tedious sometimes.
  • Tony R.
    38
    • October 9, 2021 at 3:59 PM
    Quote from EnergyAddict
    I see. So it may be possible to pick the desired part depending on a numerical register, perhaps some sort of IF/SELECT pick simulation?
    This is perfect information, Thanks man.
  • EnergyAddict
    45
    133
    • October 11, 2021 at 1:44 PM
    Quote from Tony R.
    Yes, This is possible in a few different ways, you can either create a regular TP program that calls different Simulation programs, or you can do it inside of a simulation program. Either way, you will have to call a simulation program at some point in your main program to get the animation to work.
    FYI, The "!" instruction is like a comment but if you add a "?" afterwards you can then type out regular tp logic.
    Also this guy, Timothy Mehring Youtube, has some good videos on Roboguide simulation if you are new to it all.
  • Tony R.
    38
    • October 11, 2021 at 3:13 PM
    Thanks man, this is priceless.
