Ayuda con motosim
Tengo el motosim eg vrc 2020, y quiero transformar el trabajo con la opción de trabajo relativo. El problema es que no obtengo la opción de trabajo relativo.
Ayuda con motosim
In MotoSim EG-VRC, go into Maintenance Mode, SYSTEM, SETUP, OPTION FUNCTION. You can turn it on there.
Perfecto funciono !!!!
Para agregar la instruccion de Touchsense (RCH), como se activa.
Mil gracias por la ayuda
No problema mi placer.
Your Spanish is amazing 95
He also wants to know how to activate Touch sense
To use touch sense you must load jobs on the controller, the jobs are MACRO jobs and you need MACRO JOB function that must active on your controller.
In the Morosim you can active same as relative job in the option function menu.
Thank you Google Translate.
I forgot to tell you, Your controller must have the search function enabled before because touch sense use this function for find the workpiece.
