Failed to load
  • Hello,
    I'm having a problem in loading a backup. It says that it failed to load and gives me a line and a column. In that line, there is a macro witch i have to comment so I can load it.
    What is strange is that i can't even load the same file that is in the robot.
    Thank you for you input!
  • Hi Sergio
    Welcome to the robot forum
    Maybe your robot software does not have the conditions to run check the macro
    What do you mean when you ask ?
    You mean, you can backup it up and not restore ?
    somar
  • Yes, If I do a backup of the ASCII files, I can't load the same file ls (tp works fine) file. To do it, I have to comment all the macros, load it, and after add the macros again. Can't understand why.
    For exemple:
    /PROG S02PROC1
    /ATTR
    OWNER = *;
    COMMENT = "*";
    PROG_SIZE = 7106;
    CREATE = DATE 21-08-19 TIME 09:49:02;
    MODIFIED = DATE 21-08-19 TIME 09:49:02;
    FILE_NAME = S01PROC1;
    VERSION = 0;
    LINE_COUNT = 138;
    MEMORY_SIZE = 7446;
    PROTECT = READ_WRITE;
    TCD: STACK_SIZE = 0,
    TASK_PRIORITY = 50,
    TIME_SLICE = 0,
    BUSY_LAMP_OFF = 0,
    ABORT_REQUEST = 0,
    PAUSE_REQUEST = 0;
    DEFAULT_GROUP = 1,1,*,*,*;
    CONTROL_CODE = 00000000 00000000;
    /APPL
    SPOT : TRUE ;
    SPOT Welding Equipment Number : 1 ;
    /MN
    1: !******************************** ;
    2: !* ProgramName: * * ;
    3: !* PlantName: * * ;
    4: !* Robot: * * ;
    5: !* Application: SPOT WELD * ;
    6: !* Path: SPOT WELD * * ;
    7: !******************************** ;
    8: ;
    9: !* Start Cycle Time * ;
    10: TIMER[4]=RESET ;
    11: TIMER[4]=START ;
    12: ;
    13: !* DECISION CODE = 1 * ;
    14: GO[3:0:DecisionCode]=1 ;
    15: ;
    16: !* ACK CODE FROM PLC * ;
    17: WAIT DI[39:OFF:AckDecCode]=ON ;
    18: ;
    19: !* PATH SEGMENT TO WELD * ;
    20: Set Segment(10) ;
    21: ;
    22: !* Enter Tool Zone 1 UBA155FX01 * ;
    23: Enter Tool Zone(1) ;
    24: ;
    25: MESSAGE[MOVING TO WELD 155FX01] ;
    26: ;
    27: !* SET UFRAME NUMBRE * ;
    28: UFRAME_NUM=0 ;
    29: ;
    30: !* SET UTOOL NUMBER * ;
    31: UTOOL_NUM=1 ;
    32: ;
    33: !* Welding in Process * ;
    34: DO[183:OFF:WeldingInProgress]=ON ; .........
    I have to change to:
    /PROG S02PROC1
    /ATTR
    OWNER = *;
    COMMENT = "*";
    PROG_SIZE = 7106;
    VERSION = 0;
    LINE_COUNT = 138;
    MEMORY_SIZE = 7446;
    TASK_PRIORITY = 50,
    TIME_SLICE = 0,
    BUSY_LAMP_OFF = 0,
    ABORT_REQUEST = 0,
    PAUSE_REQUEST = 0;
    /APPL
    SPOT : TRUE ;
    /MN
    2: !* ProgramName:* * ;
    4: !* Robot: * * ;
    6: !* Path: SPOT WELD* * ;
    8: ;
    12: ;
    15: ;
    18: ;
    20: ! Set Segment(10) ;
    21: ;
    23: ! Enter Tool Zone(1) ;
    24: ;
    26: ;
    28: UFRAME_NUM=0 ;
    29: ;
    31: UTOOL_NUM=1 ;
    32: ;
    Thank you
    Edited once, last by Sergio Guerreiro: wrote the wrong program extension ().
  • Shouldn't they be called different ? With the underscore
    18: ;
    20: Set Segment(10) ; .......................Set_Segment(10)
    21: ;
    23: Enter Tool Zone(1) ; ...................Enter_Tool_ Zone(1) ;
    24: ;
    somar
